Our ARG7302WW range is missing the temperature sticker for the dial...where should 350 degrees be and does it go up in temp clockwise?
Hello- The background panel is screened with gradients, but is expensive and hard to find. The easiest solution is to purchase an oven thermometer and allow to set for about 20 min at an indicated 350deg. Make sure that dial knob is tight and mark with a line at that point. Use a fine point sharpy, and clean surface before marking. Turn off, let cool, and turn to the new 350 mark and see if temp comes up and matches 350deg on thermometer. If it works ok, try marking 325, 375, 400, etc. ---Yes, Clockwise is up in temp. Let me know if this info helps. Have more if needed- Thanks - Ed
