20 Most Recent
Smeg SE250XUK Stainless Steel Electric Single Oven Questions & Answers
Oven will not switch on
My Smeg oven will not work either. All I get is an "A" on the display, the clock has disappeared and as a result the oven won't come on. I see from other postings here I can bypass the clock so that the oven works again - can anyone advise how I do this?
Fan forced element is broken
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
- Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
- If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
- When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oven not working but grill is please help
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Smeg SNZ91MFX1 Fan heating not working
If this helped like us on facebook please
SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
