20 Most Recent
Smeg S1100MFX5 Electric Single Oven Questions & Answers
I have a Smeg oven
I have a Smeg Double Oven DO4SS-5 that I need to remove the control panel on
it. I've removed the 2 bottom screws but is still reluctant to come off. Help please
Smeg S1100MFX5...
Answered
on Aug 24, 2015
Not heating up beeps continuously
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
- Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
- If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
- When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
http://how-2-repair.com/buy-paul-a-beer/ Paul is from the Naturally he would appreciate beer How to Repair Home...
Smeg S1100MFX5...
Answered
on Mar 06, 2014
Circuit braker trips as soon
It is possible there is a heavy short on the oven and so the circuit breaker cuts off the supply when the oven is switched ON.
You will need to disconnect the coils to the ovens one by one till it is confirmed of the shorted coils. A test of the coil also will indicate the fault. If this is a ELCB then the ground leak within the oven /poor ground connection of the outlet can also cause the issue. make sure there is no damping in the connections of the power to leak and trip the circuit.
Smeg S1100MFX5...
Answered
on Jun 17, 2011
How can I get a
Open the webpage :-
http://www.devicemanuals.com/model/SMEG_S1100MFX5_manual.html
Click on the English option.You would be directed to a new page.Enter the validation code ( 4 alpha numeric characters ) and click download. Then, you could save the manual.
You need to have acrobat reader to view the file. Any other issues, revert and i could upload the manual in rapidshare or mediafire.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Smeg S1100MFX5...
Answered
on Sep 20, 2010
