20 Most Recent Smeg SE210X/1 Stainless Steel Electric Single Oven Questions & Answers
Need new stickers for control panel
Hi Camilla. I used ovenlettering.co.uk they made me new stickers and they won't clean off.
4/23/2014 7:48:28 AM • Smeg SE210X/1... • Answered on Apr 23, 2014
Hi Our oven wont turn
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element. Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
3/6/2014 12:50:05 PM • Smeg SE210X/1... • Answered on Mar 06, 2014
Hi smeg se210x/1 doesnt want to heat up to a
3/6/2014 12:43:49 PM • Smeg SE210X/1... • Answered on Mar 06, 2014
Blows mains fuse
3/6/2014 11:39:56 AM • Smeg SE210X/1... • Answered on Mar 06, 2014
Oven lights come on, clock works, nothing else works won'heat up or anything
Check online for your oven and it might show different problems with that type. Also, my oven did that and it was just the heating element on the bottom. The top one was working okay. I looked on Amazon and found the right one by range model #. It only costs about 20.00 and easy to install. If that isn't the problem, it might be the wiring in the back. If that's the case I would call someone.
2/13/2014 11:10:56 PM • Smeg SE210X/1... • Answered on Feb 13, 2014
0answers
The oven turns off completely after 20 minutes or so, educated guess i soverheating
check the timer or replace it
3/25/2012 3:20:25 PM • Smeg SE210X/1... • Answered on Mar 25, 2012
Do you have a softcopy
Well you may please follow the link below to get your manual -
http://safemanuals.com/user-guide-instructions-owner-manual/SMEG/SE210X-1-_E
Good Luck!!
Thanks for using FixYa!!
3/27/2011 7:23:23 AM • Smeg SE210X/1... • Answered on Mar 27, 2011
My light bulb keeps blowing
Perhaps you have up to 240 V on the lamp socket and you are installing a 120V bulb. Check for wiring faults, especially an open neutral or ground connection in the oven. If the lamp socket neutral is connected to the neutral on a lower-resistance device on the other leg, but the wire connecting these two items is not connected to the power cord neutral, the voltage across the bulb will be more than it can handle. In this scenario, the other device (heating element, timer, or whatever) will probably not work or will work poorly after the bulb blows.
11/4/2010 6:46:05 AM • Smeg SE210X/1... • Answered on Nov 04, 2010
When turning on the oven
If the fan is working o/k, then it is going to be the oven element that is faulty. This is located behind a removeable cover at the rear of the oven compartment.
10/27/2010 7:47:16 PM • Smeg SE210X/1... • Answered on Oct 27, 2010
0answers
No heat when oven is turned on, fan ok
did you check if the element is craked could need to be replaced. even if you don't see anything check with ohm meter make sure there is some resistance (over 20) also try oven on boiler see if that helps
5/18/2010 5:38:27 AM • Smeg SE210X/1... • Answered on May 18, 2010
Smeg SE210X/1 Stainless Steel Electric Single Oven Logo
36 questions posted
Top Smeg Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Paul Carew
Are you a Smeg Oven Expert? Answer questions, earn points and help others
View Most Popular
Smeg Ovens
  • Smeg Ovens
Most Popular Question
oven lights come clock works nothing
  • Ovens
