Question about Edirol UA-25 External Sound System
SOURCE: SONAR LE NO AUDIO
make sure, if you are using windows you have the right sound card settings (control panel->audio and sound devices or however) as mentioned in the manual. Also, using sonar LE make sure to have correct settings (options->audio settings). i had trouble with playback too but now everything's working fine. in my sonar settings i use the ASIO driver mode, and mark 'share with other programs'. make sure the right sound card is selected too (options->audio->drivers) and then it sould appear in the advanced window (as for the playback and the record timing master). other possible solutions might be in the options-> midi devices window, though i doubt that. I hope this can be helpfull. Good luck! btw, any solutions on how to NOT get the registration window on the startup?
Posted on Sep 22, 2007
SOURCE: no midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Posted on Sep 22, 2008
SOURCE: Have been using Edirol UA-20 successfully with
where did i can find 4PM266PM multimedia audio controller driver..
Tq
Posted on Jun 06, 2009
SOURCE: "unable to open audio recording device. Device may not support..
sorry its a software every time when you recieved a fetal error its came from software's corrupted dll file
Posted on Aug 30, 2009
Microsoft re-engineered the audio bus for Windows. HD Audio is hardware specific, in the sense that specific drivers have to be written to make a piece of hardware compatible with it. Roland is not writing a driver for the UA 25 because they want you to buy an UA 25EX. Get my drift? The UA 25 uses Kernel Streaming, the old way, which exists in parallel, sort of, with the HD Audio bus. But the new ways are always prioritized over the old ways in software, so there is bus contention (glitching).
To fix this there are a few things you can try:
1) Roll back to SP2. SP3 implements the HD Audio bus, so don't use that implementation. If your laptop has an HD audio sound card then I doubt it would work, but your UA 25 would.
2) Try ASIO 4 ALL. This fixed everything but glitching in VST instruments.
3) Reduce the amount of stuff your computer is doing. Optimize your OS by turning off the cute shaded windows and desktops and various processes that you don't need to see or use. There are sites for this. This increases available RAM, CPU time, etc.
4) Video hardware acceleration, sometimes, would fix bugs in software left in by not so clever programmers.
4) You can always just give-up and go along with the bastards and buy new stuff and toss the old stuff.
-SQA MGR
Posted on Sep 15, 2009
Dec 01, 2014 | Computers & Internet
Sep 03, 2013 | Cakewalk SONAR 7 Producer Edition -...
May 28, 2012 | Cakewalk SONAR Home Studio 7 XL for PC
Apr 16, 2010 | Cakewalk SONAR 7 Producer Edition -...
Dec 23, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Jan 20, 2009 | Edirol UA-1000 External Sound System
Oct 11, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Sep 21, 2008 | Edirol UA-25 External Sound System
Sep 04, 2007 | Edirol UA-25 External Sound System
Jul 05, 2017 | Edirol UA-25 External Sound System
Dec 14, 2017 | Edirol UA-25 External Sound System
97 people viewed this question
