SOURCE: VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
SOURCE: what kind of cords do you need to hook-up to a tv??
Hi and welcome to FixYa,
Offhand, the A/V cable would be readily available from most electronics supply store, Audio/Video/TV stores, MP3 and even computer shops/stores. The cable would be as shown below:
Alternately, you can connect the RF OUT of a VCR to this RF/ANT/Cable IN of the TV, set the TV to Channel 3. An RG59 patch cable would do the job. Should you want to connect a DVD, connect the Video/Audio OUTPUT of the DVD to the Video/Audio INPUT of the VCR. Incidentally, the regular cable/ant should be connected to the RF IN of the VCR.
Good luck and Thank you for using FixYa. Happy Holidays.
SOURCE: Emerson VCR/DVD player. A VHS tape plays in color,
Check on the dvd menu about the video format
SOURCE: I can play dvds but not vhs. how do i hook it up
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
