20 Most Recent Jwin Electronics JD-VD138 DVD Player Questions & Answers
2answers
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
1/4/2022 6:34:16 AM • Jwin Electronics... • Answered on Jan 04, 2022
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
5/21/2015 8:37:28 AM • Jwin Electronics... • Answered on May 21, 2015
0answers
Problems with Jwin Electronics JD-VD138
I just found this answer from another contributor.
Turn the power on
Close the drawer
Press 9735
Select Region 0
Exit Setup
You now have a multi zone DVD
3/22/2009 10:02:31 AM • Jwin Electronics... • Answered on Mar 22, 2009
Dvd will only play in black and white any help
Are you using the composite input on your TV? If so, you might have plugged the input cable into one of the other video outputs on the DVD player. There may be a switch on the back of the DVD player to select the output format.
2/22/2009 4:07:39 AM • Jwin Electronics... • Answered on Feb 22, 2009
2answers
TV plays color, dvd black and white
If I understand your post/description, the DVD plays OK except it is in Black & White. If so, change setting from PAL to NTSC or vice versa depending on the region you are in. US operates on NTSC, Most of Europe is PAL.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
1/20/2008 8:38:58 PM • Jwin Electronics... • Answered on Jan 20, 2008
Can you tell me which universal remote will work with my jwin DVD surround player please
Don't buy a Universal Remote, buy one that is made as a replacement for your model. That is called a Facsimile Remote. https://www.google.com/search?q=jwin+DVD+surround+player+replacement+remote The search query is 'make model replacement remote'. ..
1/22/2022 1:30:52 AM • Jwin Televison &... • Answered on Jan 22, 2022
0answers
0answers
Tv wont reset
Replace its main system control memory IC, and make an initialize. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
5/11/2013 11:03:49 AM • Jwin Televison &... • Answered on May 11, 2013
2answers
Supergirl 13 color tv/dvd combo plays CDs but not DVDs...
If cleaning did not fix it the optical pickup for that unit is damaged in some way---if the set has audio/video INPUT jacks on it just buy a DVD player and hook it to the set.If no jacks you are finished--DVD portion of the unit if available costs more than the entire set.
4/5/2012 9:46:05 PM • Jwin Televison &... • Answered on Apr 05, 2012
Jwin Electronics JD-VD138 DVD Player Logo
Popular Tags
7 questions posted
Top Jwin Televison & Video Experts
ExpressFiX
ExpressFiX
ADMIN Andrew
ADMIN Andrew
Vinho Xie
Vinho Xie
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jwin Televison & Video
Most Popular Question
tv plays color dvd black white
  • Televison & Video
