20 Most Recent Funai LC427SSX 42 in. LCD TV Questions & Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Funai LC427SSX... | Answered on Sep 02, 2017
check batteries on the remote/or hide remote and see if it stops/if not bigger problem
Funai LC427SSX... | Answered on Dec 04, 2016
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Good luck.....
Funai LC427SSX... | Answered on Aug 11, 2010
Hi my name is Roety,
I can help you with your issue ,
If this is not a label setting  you may need a new mainboard.
Funai also make Sylvania the mainboard probably cost about $200 ck at encompassparts.com
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Funai LC427SSX... | Answered on Mar 01, 2010
Sorry to say. but sounds like a bad screen you have there.
Funai LC427SSX... | Answered on Jan 04, 2010
Where dose not firmware find Funai modal 29fl513/94
Funai Televison... | Answered on Mar 12, 2019
BAD POWER SUPPLY BOARD IS USUALLY THE PROBLEM ON FUNAI WALMART. WHAT IS WORSE WALMART MAKES SURE U CANNOT GET PARTS TO FIX IT.
SOME ELECTRONIC SERVICE SHOPS CAN REBUILD BUT IS IT WORTH IT ON A FUNAI
Funai Televison... | Answered on Feb 08, 2019
TRY THIS BUT ITS ONLY 50 PERCENT LIKELY TO WORK THESE UNITS ARE SPECIFICALLY FIRMWARED TO ONE REGION
https://www.youtube.com/watch?v=EdiJQBT2DPE
Funai LC427SSX 42 in. LCD TV Logo
15 questions posted
Top Funai Televison & Video Experts
Ekse
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Funai Televison & Video
Most Popular Question
no picture power light blinks couple
  • Televison & Video
