As per one of my other posts:
Press the 'OK' button, then it'll prompt you to 'Save All Data To PC'.
If you have dictation on the portable that you want to save, connect it
to the PC and hit 'OK'. It'll go into 'PC Operation Mode' and you can
transfer your dictation like you normally would. Then when you
disconnect and reboot the portable, you should get the error again.
To
clear the error, press 'OK' again, but on the 'Save All Data To PC'
screen, instead of pressing 'OK', press 'Esc' (I think that's the other
option - this is from memory!) and it'll prompt you to delete the data.
Press 'OK' and it'll format the memory and reboot - then you should be
good to go.
The 2003,1001 error is caused by shutting off or cutting
power to the portable while it's still in the Record mode. The portable
is writing to the memory, and if you cut the power, it doesn't have a
chance to finish saving the dictation - resulting in a corrupted file.
