Question about Dictaphone Walkabout 5210 Digital Voice Recorder
Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it back to original?
Posted by bill_rolston on
  • 1 more comment
  • Anonymous Apr 30, 2009
    I'm afraid I cant help except to express solidarity - mine just did the same thing today, having behaved beautifully before that. A quick google failed to find any easy non-techy way of converting back.
  • Jess Feb 10, 2012
    Mine has done the same thing. Now the buttons are not even responding. : (
  • Anonymous Mar 31, 2014
    how to erase data from a Mikomi model: ET858
Anonymous
Hi all,
I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
Turn on
Press 'M' to cycle to 'REC' mode
Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
Record as usual.
I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
If anyone knows what VOR is then please shout back.
Hope this helps.
Liam
Posted on Jun 08, 2009
Anonymous
  • 3 Answers
Vor (voice control record) is voice activated on/off set up on page 13 of english manual it is to conserve space when recording in .wav format to make any change from sp Lp sp+vor etc start on page 12 Menu setting and work through takes some bit of time but it will work setting appears to turn the device off ofter 3 sec and on again when another sound is made
Posted on Sep 23, 2009
Anonymous
Many thanks to Liam here, only just bought my dictaphone to help me @ college but couldnt listen to it on my computer, now i can!
Posted on Oct 10, 2009
RCA Voice Recorder VR5231-A audio files doesn't play in my PC
Save first your audio file to wav file format, then open it using Windows Media Player...
May 06, 2010 | RCA RP5016 Digital Voice Recorder
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
I have an RCA Rp5120-a digital voice recorder. I have been converting my files to wave than to mp3 files. Now everytime I try to transfer them I am told the file is corrupt and cannot be copied! Does...
first bring it in on a pc use the soft ware in the rca recorder then save as a wav because ti is voc file..so now it is a wav file you canplay a wav file if you can't.open it in quictime and save it in quicktime and every plays QT. thank you hope this works
Apr 04, 2009 | RCA RP5010 Digital Voice Recorder
Can I save a WAV file to MP3 format
There is a free program called Media Monkey - it will convert WAV format to Mp3 (actually, it will convert any non-protected music file type - it's very dynamic). It may take a while to figure out how to do the first one, but it will get easier after that.
First, you have to plug the Thomson in to your computer, double-click "My Computer," and then double-click the icon of the Thomson. There should be a folder called "Voice or "REC". If it doesn't show up, select in the window: Tools --> Folder Options --> View --> select Show Hidden Files and folders. Now the right folder should show up. Then, drag the WAV recording to your desktop (or your "My Music" fodler - whichever works best for you), and the computer should make a copy of the WAV recording onto your computer.
Now open up Media Monkey and it should, after several minutes find all music files on your computer, including the WAV recording. Then right-click the WAV recording, and it should have an option to covnert the file type - convert to mp3, and you're done.
-Tha Mp3 Doctor
Mar 22, 2009 | Thomson Lyra PDP2842U MP3 Player
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
Dragon software
Forget about soundwave, I don't know if it saves 16 bit Wav or mp3.use Wavelab it is easier just open the files and do save as and chose format 16 bit. You can do the same with soundforge.
Whatever software you use , you use just (File button on top left)command open and save as or export, and when saving you set 16 bit wav. It is not to difficult.
Some of this software has many feature use solo basic file open save as or export
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
WS-300M Olympus Voice Recorder
you can rewind a tad and listen, but you can't overrecord, because a digital recorder writes audio information into a data file and saves it. you just can play it back again and record a new file. if you want to cut off a part of your recording, you have to edit the file in an audio editor. - as the olympus stores wma-files, you'll have to convert them into wav format first to edit them. i tried the 'switch' software successfully.
Aug 13, 2007 | Olympus WS-300M Digital Voice Recorder
Dictaphone Walkabout 5210 Digital Voice Recorder Logo
2,025 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
