Question about Dictaphone 1740 Desktop Cassette Transcriber / Recorder
The dictaphone wont rewind or fast forward and makes a bleeping noise
Posted by gillhemps on
Anonymous
    New Friend:
  • 3 Answers
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Posted on Dec 07, 2010
I have just bought a Dictaphone express writer 1740. It rewinds and fast forward but does not play properly. It is in excellent condition. We are using micro cassettes. The manual said this machine can...
This unit takes mini cassettes, not micro. A common issue with the playback on this model is the rubber tire on the drive reel cracks, causing it not to turn. It probably needs to be replaced.
May 08, 2011 | Dictaphone 1740 Desktop Cassette...
JVC VRC MACHINE HR-S7965 Rewind/fastforward cog slip noise
maybe a broken break band on reel supply (left one) in the vcr !!!
Apr 22, 2010 | JVC HR-J461MS VHS VCR
Is there any fixing with this problem of model 2740 that wont do anything rewind, play, fast forward etc just clicks clicks
your unit has a broken cam gear you need to sen it to repair here are a place
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Nov 20, 2009 | Dictaphone 2740 Desktop Cassette...
Dictaphone ExpressWriter system - tape will not rewind, play, ff
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
Jul 24, 2009 | Dictaphone 2740 Desktop Cassette...
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
How do you erase dictation from a Lanier dictaphone?
Dec 17, 2008 | Lanier 260T Desktop Cassette Voice...
Dictaphone 3750 transcriber
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
Sep 09, 2008 | Dictaphone 3750 Desktop Cassette...
Problems with recording/rewind/fast forward
You probably have a bad power supply. But as you will learn, repairing any VCR will cost more than buying a new one.
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Nov 04, 2007 | Dictaphone 2740 Desktop Cassette...
Dictaphone 1740 Desktop Cassette Transcriber / Recorder Logo
394 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
