ASUS P5PE-VM Motherboard Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch connectors, i plugged in the power cord and mobo on-board LED went green and then power up the mobo. CPU fan, power supply fan, and aux fan turned on, however i never heard any beep sound. most of my test with this process I often heard beep sound so i can determine the problem of the mobo. Camn anyone help me please, trying to save friends computer.
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Jan 13, 2011
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
528227
Points
7608
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
How much video card memory does the p5pe-vm board supports? cause i have installed the geforce 6600 256 mb , and it only detects 128mb.. and when i run dxdiag , it says there ( approximate memory: 1
Eyaa! Use www.systemrequirementslab.com ant take one random game to check your computer performance, there it will show your computer performances.
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Pciwifi card "not connected" and work no more
replace fuze and battery something shorted both of thouse out.
Can i put video card on p5pe vm? and what video card
It has an onboard video, so you don't need one, but if you want to add a better one it must be an AGP 8X/4X card and must be +1.5 volts.
A manual for your board is:
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf
look at page 1-20 about video cards
I have a p5pe-vm mbord and fx 5500 vcard issue.
is your video card brand new? try to check and try using other card to sure that the problem in the card or in the slot.
PCI video card on my P5PE ASUS motherboard
Your motherboard is equipped with an AGP slot, you would want to use this to add a video card, but first you must go into the BIOS and disable the on board video graphics chip so you can utilize an external video card. This will make your pc faster because of the independent processes and memory the card will have on its own, not needing the pc's memory to run, thus taking away from system resources. Take a look at these:
http://www.buy.com/prod/visiontek-radeon-hd-3650-agp-512mb-ddr2-128-bit-directx-10-1-video-card/q/loc/101/211110588.html
http://www.ewiz.com/detail.php?p=EV-A62_512&c=pw
http://3btech.net/sa8xagpatira.html
Listed find the low, medium and high ranges of video cards. I hope this helps.
1helpful
I have a P5PE-VM motherboard i install all driver and the video card also but i suffer log during gaming.... i have 1G memory..... help
This is not the video hanging you up, Check a couple things like try resetting your modem, defragging you hard disk, add more system memory. Your question is a little vague because you did not include the game your playing or any more technical information so if this information is a help please rate accordenly thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Can i install pci video card in my p5pe-vm board ?
You could by why would you?  Even your " on board" graphics are faster that an PCI video card would be. You have a AGP 8 slot. Look for a really good AGP 8 video card. That should get you where you want to go. It will not be as fast as a PCIe16 card but you do not have that option nor slot of *********** board.
Below is the ASUS link to your board. http://www.asus.com/search.aspx?searchitem=1&searchkey=P5pe-vm
1helpful
CMOS Settings is Wrong! USB Device over Current Status Detected!
It would seem that you posted twice, pls see you other post.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
