Where is it leaking from? Around the edges of the cover?
You may need to make a new gasket for it.
Drain oil by remove lower bolts and slightly prying on cover so fluid starts draining.
Slowly make your way up to the top bolts until it's completely empty.
Remove cover, clean old gasket off housing and cover.
Attain gasket maker from any auto store, and spread a even amount around edge of housing, where the cover and housing touch..
Replace cover, fill with oil, and see if this stops the leaking. If not, you may have just rusted out the cover, after years of wear and rust (depending on the year of the vehicle) and may need to simply replace the cover.
Only major problem is it would be leaking from the side or where the drive shaft enters the housing, which would require new seals, and a bit more work!
I hope this helps!
