HP Pavilion a1240n (EG136AA) PC Desktop Logo
Posted on Jan 10, 2011
Hp Pavilion a1240n sound driver i want pls give link my email pls help me urgent
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
754
Points
This Realtek Audio Driver ALC880 ALC882 worked for the HP Pavilion a1240n (EG136AA) I've put all five RAR parts into 1 compressed folder
Here--> http://www.mediafire.com/?fls50o85uo2o7t0
(Thanks goes out to Gamefront!)
All five parts can be obtained individually
Here--> http://www.gamefront.com/files/4209729/Realtek_ALC880_882_Audio_Driver_V5_10_0_5127_1_5
1helpful
No Sound, Sound device not showing up on HP a1240n motherboard D33005
you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
cleaning your computer of dust using a fine air blower from a compressor making VERY sure that
there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD you might even remove the sound card to clean the socket dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
I upgraded my hp a1240n with windows 7 but Ihave no sound
1. Check under device manager if you have audio device driver.
2. If no device driver download the audio device driver (check if you have win 7 32 bit or 64bit this is important) if there is audio device driver uninstall and reinstall the driver.
Check the link below from HP.
1. Go to the link
2. Go to > Select your product
3. Select operating system
4. Below there will be the list of drivers
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=12454&prodSeriesId=1118267
If you were able to install the driver for win 7 and still nothing happen it is a posible hardware issue.
http://welcome.hp.com/country/us/en/welcome.html#Support
2answers
I need free install sound driver for my laptop hp pavilion dv 6000 pls. help me urgently [email protected]
I will give you a easiest way for finding the drivers that you need for your hardware.Just download the soft ware name d drivermagician. Install it and it will search for the drivers that is not installed for the hardware you have through internet and will download it for you.here is the link for that softwarehttp://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html Thanks, Mukund Ubhadiya www.einfochips.com
12helpful
7answers
HP Pavilion dv1000 PC Notebook Audio Problem
There are two different audio cards shipped with Pavilion DV1000 series Notebooks.
If your Notebooks belong to DV1600 series, your Notebook should have been shipped with Conexant High Definition Audio card.
This can be one of the reason why you are unable to install the Conexant AC Link audio drivers in your Notebooks.
You need to install Microsoft UAA Drivers first before installing the Conexant High Definition Audio Drivers in the Notebook.
Download the Microsoft Universal Audio Architecture(UAA) Drivers for your Notebook from the HP link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Please save the file in the Notebook and double click it after the download completes to install the drivers. Restart the Computer once the installation of the Microsoft UAA Drivers is completed.
Now download the Conexant High Definition audio drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Save the file and double click on it once it is saved to install the Drivers.
This should solve the issue with audio in your Notebooks.
Hope this helps...
4answers
Sound and audio devices problem
hi frind
u need to install your lapotop driver when install driver then sound come so install your motherboard driver cd in your lapotop
if u not have driver cd tell me your laptop model no so i can give u link to downlod driver
3answers
13helpful
10answers
HP Pavilion dv1000
I found out how to fix the no sound problem on The HP Pavilion DV1000 Look under Dv1310 thats the model number the driver your looking for is SP30262.exe
HP a1240n recommended upgrades
HP a1240n has no AGP or PCI-E Slot, so your left with PCI VGA CARD.
Here is a link for PCI video cards.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609642&bop=And&Pagesize=100
Pick the card that suites your needs ( Pick those with Direct X 9)
note: The higher, the core clock, The better.
The higher the memory and bit, the better.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
