Whirlpool LSR6334LQ Top Load Washer Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to open a whirlpool lsr6334lq0 model to replace the connector switch?
Anonymous
Level 2:
New Friend:
  • Expert 126 Answers
  • Posted on Jan 09, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
126
Questions
0
Helped
54028
Points
242
Remove the moldings on the upper left and upper right corners theres a philips screw under there that you take out and the complete cover tips off towards you.
1helpful
2answers
Estate by whirlpool model SM8280867. Filled, then stopped. What's wrong?
Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
1helpful
F5 E1 error. Oven door won't open after running cleaning cycle
1.
If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
F5 - E1
2helpful
Getting a E6 F2 error code on my Whirlpool GBD307 Oven
F2 - E6 Cancel key drive line open1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
2helpful
2answers
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2answers
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
WHIRLPOOL LSB6000PQ0, FILLS BUT DOES NOT DRAIN, THINKING THE TIMER NEEDS REPLACEMENT?
Slide a old CD under the left and right front corners of the control console to release cabinet clips. Fold the console to the rear of the machine. Unplug the lid switch plug at the connector. Take a volt meter set for continuity and place the leads in the lid switch connector. Open and close the lid. If you have continuity the lid switch is good and you should replace the timer. If you have no continuity replace the lid switch.
Range with Error Code F5 E0
HI.The Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door)
1. If door latched:
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
1helpful
2answers
Have whirlpool accubake oven model # RF386PXGT turned on the auto clean error code E1 F5
Self clean latch will not lock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
F5 error on Whirlpool Accubake Range
1. If door latched:
a) Disconnect power from unit.
b) Check wires and connectors from control to door switch,
and all connectors okay, proceed to step c.
c) Replace door switch.
d) Re-apply power to unit and verify operations.
b) Check wires and connectors from control to latch switch,
c) Repeat steps a) and b) for door switch.
voltage terminals).
4. Measure latch switch (unlatch = switch open. NOTE: Oven
5. If corrections are made in any step, reconnect control to
verify correction.
6. Check door alignment.
7. If failure remains, replace control.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
