20 Most Recent Whirlpool RBD275PD Electric Double Oven Questions & Answers
What caused it to go dead?
1. Open fuse/circuit breaker 2. heating element failure
3/15/2021 6:01:56 PM • Whirlpool... • Answered on Mar 15, 2021
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
8/7/2019 6:19:31 PM • Whirlpool... • Answered on Aug 07, 2019
F2 E3 error code- Oven won't turn on now
I ended up calling a technician to come out and look at it. He said that the front panel where you push all the buttons went out and I would need to get a new panel.
8/7/2019 5:32:08 PM • Whirlpool... • Answered on Aug 07, 2019
Whirlpool double oven RPD275PD Error codes E6 (red) and F2 (green) with lock icon in between them.
you either have a bad control board or key panel but you can't get parts for this oven anymore,you'll have to replace the oven or you can try this because it sounds like the board is bad,either you or you get someone in to remove the board,you make a diagram of the wires,take out the board and send it out and have it rebuilt,it usually takes 10 to 14 days to get it back,then you reinstall the board and wire it.i've done this on older thermadore stoves,has the clock ever gone blank or anything crazy like that?if so then you know it's the board but i just googled it and these guys rebuild it for like 160 bucks and that ain't bad https://www.appliancetimers.com/appliance?model=gbd307pdt7 call them,give them your model number or you'll have to replace the oven,this is why they told you to kill the power to it to see if the board would reset,you can try that again,leave the power off for like 5 to 15 minutes and try it but unfortunately they don't make your parts anymore.good luck
12/3/2017 4:28:37 AM • Whirlpool... • Answered on Dec 03, 2017
How do I clean the lower oven for the electric double oven? I am getting an error code F3 - too hot. Can I replace the sensor or do I need an electrician ? Thanks
To play it safe, I would call an electrician if you are not comfortable doing this.
1/26/2015 1:41:11 AM • Whirlpool... • Answered on Jan 26, 2015
OVen display is blank and oven won't turn on.
Can you supply a model number?
Most likley you have a bad erc control board ( clock). But a model number would help narrow it down.
5/3/2013 6:05:37 PM • Whirlpool... • Answered on May 03, 2013
Oven does not work at all sometimes it beeps and
Hi, to fix this error code follow the instruction below...
  • Check keypad connector for firm connection (keypad connects to control board).
  • Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
3/20/2013 8:40:50 PM • Whirlpool... • Answered on Mar 20, 2013
Error Message E6 F2
Hello, Thank You for using FixYa. I will be helping you today.turn power off unplug touchpad ribbon cable from control and turn back on. If error does not return after a few hours then replace touch membrane which is the whole front on this unit. If fault shows up with membrane unplugged then replace control board.
Thank You and please rate my answer if it was helpful..
3/20/2013 8:29:47 PM • Whirlpool... • Answered on Mar 20, 2013
2answers
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
3/20/2013 7:14:42 PM • Whirlpool... • Answered on Mar 20, 2013
0answers
RDB305PDB14
Be the first to answer 3/11/2013 2:57:45 PM • Whirlpool... • Posted on Mar 11, 2013Be the first to answer
Self cleaner is not working
CALL Chas&Son,s appliance repair at 579-379-0993 and they will come out the same day no less
2/13/2013 1:02:30 PM • Whirlpool... • Answered on Feb 13, 2013
Whirlpool RBD275PD Electric Double Oven Logo
72 questions posted
Top Whirlpool Ovens Experts
W.L.
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
error message e6 f2
  • Ovens
