Expert
- Posted on Jan 09, 2011
Re: Is it any user manual available in the web? I could...
I dont think you can but you can use the instructions below to operate you washing machine
Washing
machines may have different technology, but ultimately have the same
features and purposes. They all require the proper settings, soap,
water and clothes to wash. Yet, there are some things you should know
to properly use a washing machine. Follow these steps for success in
doing your laundry.
jQuery('.intro .thumbnail').each(function(i,e){
jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); });
Instructions
Read
thoroughly your washing machine owner's manual. These instructions are
designed for your particular washing machine. If you don't have an
owner's manual, read the button control labels on your washing machine
to get an idea of what they do.
Sort
your clothes. You should wash white or light-colored clothes together
and dark-colored clothes together. Clothes should be further sorted
according to their material. Heavy fabrics should be washed together
and light fabrics should be washed together.
Add
detergent to your washing machine. Follow the instructions on the
detergent box. The detergent should go on the bottom of the washing
machine unless your washing machine instruction manual specifies
otherwise.
Use
the special bleach or fabric softener dispensers for your particular
washing machine, if you are adding bleach or fabric softener.
Otherwise, follow the instructions on the bleach and fabric softener
packaging to find out how much and when you should add them to the
washing machine.
Load
your clothes loosely into the washing machine. Load the laundry as high
as your owner's manual specifies or to the top row of holes in the tub.
Close
the lid and set the controls of your washing machine according to what
you are washing. Use hot water for only white cottons. Use warm or cold
water for colored fabrics. Set the other controls according to the
weight and durability of your clothing.
Turn
on your washing machine. Allow it to work through all of the cycles and
turn itself off before you unload the washed laundry.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
Tips & Warnings
If you're going on vacation
or not going to be using your washing machine for awhile, turn off the
water faucets to your machine. It will relieve pressure on hoses and
valves and minimize any leakage, should it occur.
Do
not leave coins, nails, screws or anything else in the pockets of your
clothes when putting them in the washing machine. They could easily
cause damage or even puncture a hole in the drum.
Do not wash items that have been spotted or soaked with combustible substances. They could ignite or explode.
If
you haven't used your washing machine for at least two weeks, and
haven't used any hot water in your household, turn on your hot water
faucets. Allow them to run for several minutes to release any built up
hydrogen gas in your water heater.
