Hi dharmeshverm, i am happy to help you, i will give your acer customer care no, its toll free to cal , call them and they will provide you guwahati authorized Customer care service address and phone no.
Ph no - 1-800-571-2237
Good luck
Hi.
The below mentioned is the Authorized Service Center for Acer in Guwahati:-
Guwahati
Acer India (Pvt) Ltd.
No.303, 3rd floor,
Orion tower, G.S.Tower, Christian Basti,
Guwahati - 781 005.
Tel: +91-361-2344556 / 2345459
Fax: +91-361-2344559.
Thank you for your patience and best wishes for your effort.
just take it back to the place of purchase im sure there will be some sort of assistance available it should be still under warranty
if you want you could have a look through all of you devices to make sure the all drivers are installed for these devices
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this post a reply
which country is Guwahati in
hope it helps
