Push the menu button. The scroll down with the arrow button till you see reports, push select button. Scroll down to Network setup page and push select to print it out. On this page you will find its Mac adres
Try to check under printer properties. Just go to Printers and Faxes > Right click on the Lexmark icon > Properties > Configuration tab > Check under Configuration options.
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray). If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
I have to ask this question of you, just to make sure this is not an issue.Are you using a factory new ink or toner cartridge? Please consider the following: If you are using a refilled or third party cartridges that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges. They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors. If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges Don
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
i believe that password would be stored on your pc in the software application uninstall it and reinstall the software. i know all of the menus and hidden menus in these lexmark printers and have never seen "password setting" in any of them.
