D-Link DIR-685 Wireless-N 300 MBps Router + 4-port Switch (790069320859) Logo
A
Anonymous Posted on Dec 27, 2010
Open port for emule - D-Link DIR-685 Wireless-N 300 MBps Router + 4-port Switch (790069320859)
Computer Links
Level 3:
  • Master 2,386 Answers
  • Posted on Dec 27, 2010
Computer Links
Master
Level 3:
Answers
2386
Questions
Helped
718556
Points
7718
Hello
The web site mentioned below helps to configure the port for emule
http://portforward.com/cportsnotes/emule/eMule.htm
Hope it helps, if so do rate the solution
Good Luck
Port forward emule
This should help. Its the exact instructions you need to forward ports with emule and your Netgear WNR2000:
http://portforward.com/english/routers/port_forwarding/Netgear/WNR2000/eMule.htm
3helpful
2answers
How do u change your nat settings to open
you can't just say nat is now OPEN :)
let's say you have a pc with IP of 192.168.1.33
you are running a emule (hehe) on that PC
you want to use port 12345 for your emule
this is what you need to do:
1. go to webinterface of your router (usually http://192.168.1.1)
2. go to menu network/nat/port forwarding
3.go to service->user define
4. in new window click "active", name it emule, start port 12345, end port 12345, server ip 192.168.1.33
5. click ok, apply, whatever and go to menu security/firewall/rules
6. choose packet direction wan to wan/router
7. click on ADD
8. change following fields: destination address - change to single address and change 0.0.0.0 to 192.168.1.33 and click on add, then close to it says ANY, mark it and click on remove
9. on same page under services click on edit customized services
10. choose number 1 or 5 or whatever :)
11. service name: emule rule, service type TCP/UDP, type single, port 12345
12. click on apply
13. go to menu maintenance/tools/restart
14. just in case restart the box and your zyxel is now accepting incoming connections on port 12345 and forwarding them to 192.168.1.33 (your pc) ...
i hope i helped
cheers
-tomba
I have a Zyxel P-660r-d1 modem and I connect to it with my ps3. But I currently have a NAT type 3, and I have some problems connecting with friends online. How do I change it to NAT type 2?
i will repost my guide for opening nat and firewall on a zyxel ...
it will help for sure ...
7. click on ADD
8.change following fields: destination address - change to single addressand change 0.0.0.0 to 192.168.1.33 and click on add, then close to itsays ANY, mark it and click on remove
12. click on apply
14.just in case restart the box and your zyxel is now accepting incomingconnections on port 12345 and forwarding them to 192.168.1.33 (your pc)...
i hope i helped
cheers
-tomba
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
1helpful
2answers
I cannot open ports TCP/UDP for eMule using router 2Wire Infinitu
You need to portforward your router to accept emules port number/numbers. Go to portforward.com. look up your router and follow the instructions. It's pretty easy.
Change low Id High ID using eMule
Where are you Santiago, and Emule is still having conflics with its scripts, just change to a another Source, I will pull itup later on tonight and see where the Problem is,...
Aloha
Kahuna
4answers
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
2helpful
7answers
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off portforward.com, and it worked for me)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
1helpful
Emule
There are several reasons why this is happening. Most likely the reason is simply because you are behind a router or firewall and the correct ports are not open.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
