The manual doesn’t show a user replaceable fuse are you plugged into a house outlet or a power strip. If power strip confirm that power is present and try another slot to plug into. https://bcc2479de3c817356f4e-1bbe459354cb22c942d9efbc3d6dacbf.ssl.cf2.rackcdn.com/product-manuals/SUB210_OM.pdf
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
