Question about Jamo SUB 250 Subwoofer
My jamo sub 250 won't power up.... any ideas i've tried a different power lead to rule out that as a problem... no change was working fine just the other day... and is only a few years old... so not real happy if it has died.... is there a reset somewhere for it... i couldn't see one?
Anonymous
    New Friend:
There is a fuse under the plug, check that first.
Posted on May 30, 2010
Testimonial: "didn't even see that fuse there... THANKS HEAPS"
Anonymous
Hello Guyz..
Even I'm facing similiar problem have brought a new jamo sub 250 with Jamo HCS 606 with Onkyo TXSR 608 . My SUb is not powering up either. Could you precisely tell me where is this fuse location . A Image would be very helpful.
I saw this fuse issue with Jam Sub250 in other forms as well. Is it common
Posted on Sep 02, 2010
  • Mike Hunt Nov 16, 2012
    unplug the cord from the sub in the housing take a flat head screwdriver and remove the plate in bottom of plug housing this will show the fuse
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
Aug 31, 2014 | Audio Players & Recorders
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
Do jamo powered subs work in the u.s.a. on 110 volts 60 hz
just buy a adaptor like a normal plug socket that your 2 pin 110 volt can plug into it then plug it in to the 3 pin 240 volt socket an bobs your uncle your sorted.
Jan 25, 2013 | Jamo A320 Hcs6 Home Theater Speaker System...
I have a jamo 250 sub and dont know which coax input to use
one will do just fine if you've tried one and its not working try to refer to manual on how to set up in the receiver function menus and if the sub is powered by an external amp which most are
Jul 03, 2009 | Jamo DVR-50 System
Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Mar 15, 2009 | Jamo SW400E Speaker
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Jan 11, 2008 | Jamo D 4SUB Subwoofer
Jamo SUB 250 Subwoofer Logo
2,211 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
