20 Most Recent Jamo SUB 250 Subwoofer Questions & Answers
You will have to take it to a repair work shop and ask for a quote.
Jamo SUB 250... | Answered on Apr 19, 2015
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Jamo SUB 250... | Answered on May 13, 2013
There is a fuse under the plug, check that first.
Jamo SUB 250... | Answered on Nov 16, 2012
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
Jamo SUB 250... | Answered on Mar 03, 2010
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Jamo SUB 250 Subwoofer Logo
25 questions posted
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jamo Audio Players & Recorders
Most Popular Question
connect jamo sub 250 marantz sr4001
  • Audio Players & Recorders
