20 Most Recent Jamo SUB 200 Subwoofer Questions & Answers
0answers
Manual pdf hom
Be the first to answer 11/22/2013 4:30:14 AM • Jamo SUB 200... • Posted on Nov 22, 2013Be the first to answer
0answers
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
10/28/2013 12:01:06 AM • Jamo SUB 200... • Answered on Oct 28, 2013
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
9/13/2012 9:27:36 AM • Jamo SUB 200... • Answered on Sep 13, 2012
0answers
2answers
The fuse of Jamo Sub-200
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
8/26/2011 9:34:15 AM • Jamo SUB 200... • Answered on Aug 26, 2011
I have jamo sub200. I
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
5/8/2011 6:10:56 PM • Jamo SUB 200... • Answered on May 08, 2011
Why is there 2 line in.left and right. and there
YOU NEED TO PLUG THE RCA INTO THE SUBOUT FROM THE AMP,THUS YOU ONLY USE 1 CABLE FOR THE SUB
4/14/2011 5:55:14 AM • Jamo SUB 200... • Answered on Apr 14, 2011
What do the phase and cut off controls do,manual
Phase reverses the polarity of the driver so it can be matched to the other speakers and bass-reinforcement characteristics of its position in the room. You don't want the sub 'sucking in' while other speakers are 'pushing out' or a bass cancellation will occur.
Set it, listen to bass from your normal seating position, reverse it and observe if the bass gets subjectively better. Leave it in the 'better' position.
Cutoff is a variable for the highest frequency where the speaker 'cuts off'. You can experiment with adjusting it for what sounds to you like the smoothest transition betwen the sub and the othere speakers. You don't want a lot of audible overlap where the sub and other speakers are acting on the same frequencies. It may sound to bassy in that area.
12/26/2010 1:47:44 AM • Jamo SUB 200... • Answered on Dec 26, 2010
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
3/3/2010 10:11:22 AM • Jamo SUB 200... • Answered on Mar 03, 2010
My Jamo 360 subwoofer is not turning ON. Last time I use it its all fine. I changed the 1 amp. fuse at the back near the 220 input socket because the fuse is blown. But it did not fix the problem.
Power supply inside has been damaged and is in need of fault dfinding and repair. Take it to a repair shop.
4/17/2022 6:24:19 AM • Jamo Audio... • Answered on Apr 17, 2022
Jamo SUB 200 Subwoofer Logo
20 questions posted
Top Jamo Audio Players & Recorders Experts
Steve
David Shaub
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jamo Audio Players & Recorders
Most Popular Question
phase cut off controls manual
  • Audio Players & Recorders
