The fault is the pump pressure is low and must be checked . make sure that in the first place there is no dirt that is clogging the filter in the pump that is causing the drop of pressure in the pump.
So remove the pump and do a good cleaning , use a reverse flushing to take out all dirt.Now make sure that the inlet to the pump is also clean.
Now reset and test the pressure. If the pressure is good then your top spray arm will will rotate and spray.
If not the pump is a suspect and must be checked for perfomance or a replacement is the other option.
Finally make sure that the voltage to the pump is in order.
thank you.will do as you say.
yes.will go and fix it now,hopefully.
