20 Most Recent Bosch HGS442UC Gas Kitchen Range Questions & Answers
HGS7152UC bosch oven door won't seal
Oven doors are designed to have some movement in and out to accommodate sealing against the gasket. If you're not getting a good seal check the condition of the gasket. If it's hard and inflexible you'll need to replace it. About 5-6 years of normal use can make these hard and inflexible. I just looked and Bosch calls this the 'Door Seal' pn 1052639
3/7/2015 9:29:51 AM • Bosch HGS442UC... • Answered on Mar 07, 2015
0answers
I have a bosch gas range and found the bake igniter to be faulty. Power to it is switched on and off properly. The broiler also does not work but I havent been able to look at that yet. Are both ignit
The broiler and oven burner are the same. The igniter can be easily(relative) replaced. Remember the igniter is ON the entire time the flame is present, so it will fail with time.
1/28/2014 7:20:33 PM • Bosch HGS442UC... • Answered on Jan 28, 2014
0answers
Touch pad not working so
For me, I had the same problem. The Solution - I unplugged the oven, then unscrewed the back of the top part and removed it. The control panel's adhesive had failed on one side, so that it came away from the glass. I pressed it back on and held it until it stuck and now it works. I expect it to fail again if my oven gets real hot, so I am looking for "hi-temp rtv" to replace the failing adhesive.
6/4/2013 5:16:27 PM • Bosch HGS442UC... • Answered on Jun 04, 2013
0answers
3answers
Bosch HGS442UC Gas Oven won't light
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
if this helps please vote me a fix ya
7/23/2010 5:51:40 PM • Bosch HGS442UC... • Answered on Jul 23, 2010
Oven wont turn on
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
5/15/2010 6:37:43 PM • Bosch HGS442UC... • Answered on May 15, 2010
My oven wont light
The problem is likely a faulty igniter. It's an easy fix, though an expensive part to replace (about $75 from APP). I had the exact problem and found this answer on another site. Just check out your igniter (under the plate on the bottom of your oven.. remove the screws in the back and lift off that plate).. the igniter is a long flat piece that should be glowing red.. if not.. that's your problem. Good luck.
3/25/2009 2:07:46 PM • Bosch HGS442UC... • Answered on Mar 25, 2009
Igniters pop about every 10-15 min
It appear that Bosch stoves are sensitive to the orientation of the hot and neutral. Mine was reversed at the outlet. I changed it to be correct and it fixed the problem
9/7/2007 5:44:31 PM • Bosch HGS442UC... • Answered on Sep 07, 2007
Bosch HGI8054UC warming drawer won't close completely
The slides require replacing.The functions part on the rear of either the right or left side has failed causing your drawer not to close. It cannot lock so the spring pushes it out. The part on the rear that locks it in, and ejects it out some how gets damaged. Need a T 20 star/torque bit to replace. The part number for the slides is 12024638. You can pull out the drawer but be careful of the rail that will stick out. Don't let the drawer land on your feet. If you don't order the parts yourself and install this, you may call the Bosch service to do such for you --though you have noted the expense.
10/22/2023 1:37:41 AM • Bosch Kitchen... • Answered on Oct 22, 2023
What are the dimensions of a Bosch WFF 2001 washing machine please
Most domestic washing machines are built to a standard size regardless of manufacturer. So if a standard machine was removed this machine should fit. The standard height is 85cm and the width is 60cm. The depth can vary depending on the drum size. A bigger capacity machine will stick out further from under the counter top.
7/30/2023 8:59:36 AM • Bosch Kitchen... • Answered on Jul 30, 2023
Bosch gas range no lower ignitor for bake no upper ignitor for broil display is fine no type of error code no other issue any recommendations?
It sounds like there is an issue with the ignition system of your Bosch gas range. The fact that the display is fine, and no error codes are being displayed, suggests that the problem is with the ignition system itself.
  • The first thing to check is the ignition switch, it could be faulty and not sending power to the ignition system.
  • Check the wiring, it could be loose or corroded preventing power to reach the ignition system.
  • The next thing to check would be the spark module, which controls the spark that lights the gas. If the spark module is malfunctioning, it will not send a spark to the ignition system.
  • Lastly, the oven and broiler igniters may be faulty and need to be replaced.
It's important to note that working with gas appliances can be dangerous, if you're not comfortable troubleshooting, it's best to contact a professional for repairs or contact Bosch customer service for further assistance. Request for a senior technician or supervisor to take a look at it and provide a resolution. Regenerate response
1/18/2023 3:26:26 AM • Bosch Kitchen... • Answered on Jan 18, 2023
My Bosch HSB745 stove is just totally off, no display but power is available and connected
Although there is power entering the range (as measured at the electrical connection for the inlet), the range will not turn on by itself. Despite the fact that there is no shortage of gas, the gas top will not light up.
5/12/2022 8:56:36 AM • Bosch Kitchen... • Answered on May 12, 2022
2answers
I have a bosch exact
Well i now have the answer to the bosch stove dilemmas if you have a glass touch panel on your bosch stove and you can't get the touch buttons to work right then check the circut board on the back of the glass it is cheaply held to the glass with a non hardening caulk and when your oven heats up the glass panel
the caulk gets so soft that the circut board and the caulk seperate causing inconsistent button operation. To solve this push the circut board and its frame back to the glass then get some aluminium tape at the building supply you shop at in the heating section and tape it into place so it can't seperate anymore then it should work for you. Make sure you have everything grounded properly.If you are concerned about the grounding you can use duct tape to be safe. ( there has been a lot of complaints about glass touch panel incosistentcies on more than one model so im 90% sure this will fix those too).
5/11/2022 10:04:35 PM • Bosch Kitchen... • Answered on May 11, 2022
2answers
Bosch gas oven will not light on bake or broil.
CALL A SERVICE COMPANY WE DO NOT MAKE RECOMENDATIONS ON GAS APPLIANCES THEY WANNA GO BOOM IF YOU MESS UP
9/2/2021 12:32:07 PM • Bosch Kitchen... • Answered on Sep 02, 2021
Why doesn't the red 'on and off' light turn off?
1. Defective switch 2. Defective wiring
6/26/2021 3:13:28 PM • Bosch Kitchen... • Answered on Jun 26, 2021
2answers
My BOSCH free standing electric range intermittently does not achieve set temperature, why?
Erratic temperature control
11/2/2020 3:06:01 PM • Bosch Kitchen... • Answered on Nov 02, 2020
Bosch HGS442UC Gas Kitchen Range Logo
23 questions posted
Top Bosch Kitchen Ranges Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Kitchen Ranges
Most Popular Question
touch pad not working
  • Kitchen Ranges
