There's probably some garbage clogging the pump.
Take the lower basket out of the dishwasher. Remove the lower spray arm. Remove the screws holding the upper pump housing and if necessary any hardware located right under the spray arm. Inspect and clean as needed. Also check the spray arms to see if there is any debris inside. I've found bleached and hardened beans, paper wads and soap/lime concretions in spray arms. I've even found a plastic pull strip from a frozen juice can in the pump (that was LOUD!).
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
