Thermador BICM24CS Espresso Machine & Coffee Maker Logo
Posted on Dec 16, 2010
Just cleaned our Thermador BICM24CS Coffee maker but we get an error message "empty trays". I emptied them, cleaned the contacts, reset the start button. Still has that error msg. If I remove trays the msg says "trays missing" which is correct. Anything I can do to fix this?
  • Capsun
    Capsun Apr 05, 2015
    Did you clean all contacts? There are some in the very front that go unnoticed
Capsun
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Apr 05, 2015
Capsun
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4459
Points
7
Did you clean all contacts ther are some in the very front that go unnoticed
Crystal Colfer
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 24, 2014
Crystal Colfer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1824
Points
Did you ever figure out a 'fix' for this? I am about to take a sledgehammer to this machine - the 'empty tray' message is preventing us from using it at all!
tip
EMPTY TRAYS!!
This just came up on our Thermador Savor built in coffee maker. I put descale in tank but accidentally pushed Clean button, rather than Calcif!! So I hit the off button...but it stayed lit green...and EMPTY TRAYS would not stop!! The trays were empty!! And I could not hit the on off button...it stayed lit green and EMPTY TRAYS continued. I had rinsed contacts, even. I can't find original answer in here right now...but I thoroughly wiped the contacts that are in the back of the tray...but there are contacts in the "front" as well. DUH! They are on the sides of front of tray. Wiped them down..lo and behold, EMPTY TRAYS went away, and now I am descaling the machine!! Oh, I also do the clean/calcif myself monthly, and I don't wait for the machine to tell me! I received this advice from foxy also. Life is good again!! Thanks FIXYA!!
Message "Fill up pipe sys" appears
Probably water level sensor bad or damaged. Possibly connections to it are loose or corroded....This is all i can find on the internet so not sure if it will help you out.
Or try this link https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Thermador+BICM24CS+Espresso+Machine+%26+Coffee+Maker+Message+%22Fill+up+pipe+sys%22+appears
3answers
Empty Tray
Hi all, I have the exactly same problem on my Gaggenau CM470 however the drip tray is clean and the contacts in the back is also 100% clean.. I wonder if its possible to disable the sensor/switch on a CM470 ?
Reads "empty tray". Tray is empty, clean, and dry. We have tried unplugging machine and resetting, The machine has not worked in 3 days.
The tray may have some redidual soiling around the electrical contacts at the back.
Try cleaning the contacts and see what happens.
5helpful
2answers
Empty tray message afyter the tray has been emptied
We had similar problem on our Z5. It turned out to be the two prongs at the end of the tray that were shorted out with dirty water. After carefully cleaning the whole contact area of the tray, the message was cleared. I would also inspect the machine itself where the prongs go in. Use a flashlight to ensure there is nothing causing the tray to misalign with the contacts. Somtimes used grounds gets stuck there and lifts the tray a bit.
1helpful
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
7helpful
3answers
Where do you put the decalcifying tablets for the thermador coffee maker bicm24cs?
They go into the water container. Make sure you dissolve them in there before you put it back on the machine. Then do the decal program.
Top Thermador Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ODEYEMI Samson
Sandile Mlambo
Sandile Mlambo
Are you a Thermador Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
