On built in machines look at the right side panel and at top left corner is an opening with a sensor (small wire runs into back of it. This sensor needs a small magnet beside it on the little metal lip of the side covering. You may find ten magnet has moved. Undo the side panel and find it - its about the size of half a tic-tac, and put it back on its little ‘perch’ beside the sensor. Door should now recognise when closed. If not, move the magnet slightly and it should work in the end.
The unit should run when out of the cabinet on its track glides. However the small cover lid (door) on top of the machine where you would put Ground Coffee in has a switch sensor on it. The cover acts as a magnetic switch and it must be in the closed position. My display says "close the lid" if left open. Since Thermador tells you to call a repairman for everything (which is hard to find one that can work on it) I've had to take every cover off for dis-assembly and repair. With all covers off the machine the only thing I had to do was to "Jump" the ground coffee wire connecter to make it run with no covers on. It makes great coffee but tough to get repaired. Let me know if that was it.
Check where the hinges on both sides enter back into the machine as the door closes. Sometimes a little piece of anything can keep the door from closing completely also check to see if anything is sticking out from the back of one of the racks. This also would keep the door from closing. Good luck.
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Open the cartridge access door.
Figure 4: Open the cartridge access door
Raise the cartridge latches for both cartridges.
Figure 5: Raise cartridge latches
Remove the protective tape from the end of the cartridges.
Figure 6: Remove tape
Insert the cartridges into the carriage.
Figure 7: Insert cartridge
Close the latches, and then close the cartridge access door.
Figure 8: Close latch
The control panel displays a message prompting you to align the cartridges.
Press the Enter button to start the cartridge alignment. Wait until the alignment completes before continuing.
If the latch is in the closed position, simply use a screwdriver to pry as if the door was being opened at the same time as you pull on the handle to open it. This will return the latching part to its proper position and you can then close the door. If the latch is already open and won't close when you shut the door, the quickest way to get it closed is to heat the latch with a blowtorch. Don't get close enough to the door that you scorch and burn the paint but heat the area arond the latch for about 30 seconds or so and the door should latch. You could also do this with a hair dryer or heat gun but it will take longer. Open and close it a few times quickly and it should work properly for a while. To keep it from happening again, once you have it working freely then spray into the latch with some WD-40 or RustCheck. Don't be shy with the spray and get it right into the latch through the door. If it keeps being a problem then before you spray it with a lubricant use a small can of lock de-icer once you have the door working. After that put the lubricant in. Hope this helps.
The sensor is inside the door and is part of the latch to close the door. It has either come loose or is broke and you will need to replace the actual latch inside the door that keeps the door closed.
To start move the cycler to the end to ternminate the cycle, and turn off the appliance. Then unplug power cable, or trip circuit breaker, cutting power for five minutes.
If when you restart the machine you still get close inner door message, then that means that the door latch must be replaced.
Hope this helps you.
This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced.
Step 1 - Remove all printheads
CAUTION:
Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children.
Figure 1: HP 14 printhead1 - Handle2 - Tower
Make sure the unit is plugged in and the power is turned on.
Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
Wait two or three seconds, then unplug the power cord.
Open the printhead latch. See the illustration below.
Figure 2: Open the printhead latch
Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below.
Figure 3: Remove the printhead
Step 2 - Reset the internal error state
NOTE:
This step must be performed before the printheads are re-installed.
Close the printhead chute.
Close the access door.
Plug the power cord back in.
Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now .
NOTE:
The carriage may make a grinding noise when you turn the power on. This noise is normal.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry.
Step 3 - Insert the printheads
Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead
Step 4 - Close and check the printer
Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below.
Figure 5: Loops catch hooks
Snap the latch into place.
Plug in the power cord.
Close the print carriage access door.
Turn on the power.
If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
