20 Most Recent Jura Capresso C3000 Espresso & Coffee Maker Questions & Answers
this is a diagram of the drip tray & drip tray contacts for the Jura S-Series S Series Impressa S7, S7 Avantgarde, S8, S9, S9 Avantgarde, S90, S95, C3000 capresso 153, X70, X90, and XS90 One Touch Models.
"EMPTY TRAY" or "EMPTY GROUNDS" (on other machines) is activated when the 2 metal contacts can complete an low volt electrical circuit through high waste water or wet caked-on coffee grounds. the area is marked in RED. careful examine this area and observe the obstruction and gunk and compare with bare clean black abs plastic. the gunk is dull and rough. use soft tools (toothpick, bamboo skewer) to scratch through the gunk. use warm water and soap and a low bristle height brush to thoroughly remove all buildup from this area. dry the metal contact and contacts area with a high percentage alcohol. visualize the insertion slots deep inside the machine (for the metal contacts marked 414) with a flashlight and verify that the female contact point pads have not been bent and are separate and distinct.
the GREEN arrow indicates a thin black plastic finger-like protrusion. this finger (when the tray is inserted) will press against the "TRAY MISSING" small white relay switch deep inside the machine. use a flashlight to visualize the small switch. verify that the switch is securely mounted and clicks when depressed (up) using a soft tool (bamboo skewer) and note the sound. verify the finger is not damaged or chipped off. listen for the sound very carefully when the tray is fully inserted into the machine. if it is not these preliminary factors, the relay switch should be replaced.
Jura Capresso... | Answered on Mar 23, 2020
Hi all, I have the exactly same problem on my Gaggenau CM470 however the drip tray is clean and the contacts in the back is also 100% clean.. I wonder if its possible to disable the sensor/switch on a CM470 ?
i have uploaded the parts breakout under the "guides" section
I have a Capresso fo 7 years now, had few problems, but always solve them.
If youe machine does all the functions properly, but doesn't give you coffee, you should check if everytnhig goes into the grounds tray. If that's the case you may only have a broken "O ring" inside the pressing element. It makes the coffe, but throws it away instead of filling the cup. I had that problem, and it was the "O ring".
If the grounds dunped on the tray are dry, you're looosing the water in the back, probably on the relief valve.
Hope this helps!
Jura Capresso... | Answered on Jan 21, 2014
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Jura Capresso... | Answered on Dec 24, 2013
Cleaning instructions for that machine can be found in the user guide at the link below:
http://www.capresso.com/pdf/super_c3000.pdf
Jura Capresso... | Answered on Nov 20, 2013
User guide found at the below link has cleaning instructions:
It could be a setting that casues this instant brew function that accidently got set. Look at the user manual?
Jura Capresso... | Answered on Oct 28, 2013
Jura Capresso C3000 Espresso & Coffee Maker Logo
45 questions posted
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Jura Capresso Coffee Makers & Espresso...
  • Jura Capresso Coffee Makers & Espresso...
Most Popular Question
capresso c1300 lcd stays stating hot
  • Coffee Makers & Espresso Machines
