Computers & Internet Logo
Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Since I had to have windows XP home version re-installed to fix a problem, I have been unable to use my headset and microphone to use Skype. My settings all confirm I am supposed to be using my Realtek HD front pink jack connection, as I always had for my Skype, but my microphone doesn't work and I can't hear anything I am using a Matrix Webcam 435C with the unit, which is working
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Dec 14, 2010
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5670468
Points
79191
Open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or
control panel sounds and audio devices audio and also voice it
2answers
I have an operating system Windows 2000 and when I installed e new version of Skype (5.3) the program refuses to start and show next message: Failed to get proc address for SetIdDirectoryW (kernell32.dll)....
System requirements for Skype 5.3
  • PC running Windows® XP, Vista or 7, both 32- and 64-bit operating systems.
  • Internet connection - broadband is best (GPRS is not supported for voice calls).
  • Speakers and microphone - built-in or separate.
  • For voice calls recommend broadband connection with 100 kbps down / 100 kbps up.
  • For group video calling everyone on the call needs Skype 5.0 for Windows or Mac or higher plus webcams, and at least one person needs a group video calling subscription. For best quality we recommend you use a high-speed broadband connection of 4Mbps down / 512kbps up and a computer with a Core 2 Duo 1.8 GHz processor. As a minimum you'll need a high-speed broad connection of 512kbps down / 128kbps up and a computer with a 1 GHz processor.
Note :Please consider in Processor, RAM, VGA and harddisk. those the main thing to decide whatever Skype 5.3 for Windows can be installed properly in computer system or not. If one of those minimum requirements can't be achieved by your hardware, please don't even try to install Skype 5.3for Windows.. Leave comment if you have something to ask!!
2helpful
3answers
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your...
On windows got to "START"
Control Panel/Sounds and Audio Devices.
Audio tab select sound card as Sound playback default device
Voice tab select sound playback default device
Open Skype got to tools/options/audio settings.Select USB device under Microphone and speakers section.
Save all settings. Works well.
I have just bought this webcam for my mac but seems unable to set up
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
4answers
Microphone not working
Hello.
1. Audio settings all versions
Skype:
Skype-->Main window…..>Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
Windows:
On the audio tab set the default playback device to your main soundcard (AC97/Audio-chip/add-on-adapter), etc.
2)Check if your micro (pink) and speaker (lime) jacks are really correct and fully inserted!
They sometimes stuck.
For test only you can use earphone instead of microphone for Line In.
Standard micro in Line In will NOT work.
Go to:
Start
Programs
Accessories
Entertainment or go to
Volume Control; right click on loudspeaker icon in Task Tray
Options
Microphone
Scroll down
Check "Microphone"
If the bar "Microphone" is available, the microphone is detected by Windows now go on
(If not, Windows has a problem with your microphone)
Just to check if your microphone is broken or bad, you can use your headphones instead. They really work!
Which one L or R is microphone now, I think it's L
Check "Advanced properties"
Check Micro "Advanced"
Open
Check "20db boost" or "1.MIC boost" depending on language version
Volume level can be left in any position.
Mute microphone!!!
3. Check audio now on windows base.
Start
Programs
Accessories
Entertainment
Soundrecorder
4. Once done, test with Skype Test Call echo123.
Good Luck
Please Vote.
1helpful
Driver updates
Go to the Acer WEB site to download the LAN drivers you need, make sure it is Windows XP version for your particular MODEL laptop.
Use this link :-
http://global.acer.com/support/download.htm
After you install the drivers and if the sound problems still occur then list the error messages etc. then will advise further.
Microphone problem
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
1helpful
Microphone does not work
Yes, sometimes Skype messes with your hardware settings and sets it up to what "skype thinks works best", if you have System Restore turned on, try going back to the time before you installed that version of Skype.
Also, look in your Device Manager settings for anything screwy.
Grand Canyon Tech
Grand Canyon Tech
