Samsung HL-S5086W 50" HDTV Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
Veril Gillette
Level 3:
Genius:
  • Master 1,126 Answers
  • Posted on Dec 13, 2010
Veril Gillette
Master
Level 3:
Genius:
Answers
1126
Questions
0
Helped
213141
Points
3124
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
1helpful
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
2helpful
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Hlp5063w lamp and temp lights blink and tv doesnt turn on
Look at turn on to see if lamp fires even for a second.
If lamp has not been replaced in 2,000 hrs it is a suspect.
If you heard a high pitched whine or fan like noise before the set failed remove the lamp and look where it faces----is the color wheel shattered or missing pieces?
Samsung HL-S5086W 50-Inch DLP HDTV keeps turning off for no reason
After turning off do the LEDs on the front panel blink on and off?
If so, you may have an issue with the lamp. Probably needs replaced or repaired.
The Samsung HL-S5086W turns off after about 20 seconds. The Standby/Temp, Timer, & Lamp lights will blink simultaneously and then it shuts down. We blew it all out to clean the dust, removed the back...
Because the problem was the lamp. The unit will not power up unless the faulty lamp's replaced with new one. Click this LINK to buy online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Jdvillanueva
My samsung HL-S5086W has a high pitched buzz that is present when muted, and continues for 2 or 3 seconds after you power off. Any ideas? I heard if it continues after power is off, then it is a fan, not...
Samsung BP96-01579A Color Wheelno the fans will not produce a high pitched noise. they will ususally produce a dull noise because they dont spin anywhere near as fast as the color wheel. the color wheel will start up before you see video and stay on for few moments after power down. if the fans were faulty the tv would give you message on screen.
2helpful
Samsung HLR5668WTV went black, replaced LAMP. Turned TV on. No picture but now there is a humming noise. TV try's to turn on 2 or 3 times then doesn't and all 2 indicators lights are blinking.
If the noise is a high pitched whine or even a grinding sound you may have a bad color wheel.
These fail quite often in these sets although it is unusual for a lamp to be associated with it. Put old lamp back and see if same problem. (unless old lamp is shattered)
If it is the color wheel I can tell you how to look at it to see if shattered without taking the set completely apart.
See attached photo of typical color wheel.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
1helpful
2answers
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
