SOURCE: Touchpad.
Click start>Control Panel>Mouse
You will see a window of Mouse Properties. Click the last tab on the top which is "Device Settings"
Highlight the SYNAPTICS Touchpad and click SETTINGS
Select the VIRTUAL SCROLLING
You will find the options as "Vertical and Horizantal"
If they are unchecked that you need to check them.
If they are already checked, than uncheck them and Apply the settings.
Again open the same window and Check the two options and save the settings.
It should work now.
If this does no work that you will have to reinstall the Drivers for the Touchpad.
I am sure that this would help. Please let me know what happens.
Please rate the solution.
All The Best.
Sammy
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
SOURCE: scrolling bar not working.
Did you try mouse properties? if not go to Start, control panel, double click mouse.
SOURCE: synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
SOURCE: how can i fix the problem of scroll tool with Hp
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
hoyagese60
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
