Question about HP Pavilion dv4000 Notebook
Scrolling bar not working.
I have hp dv2500 being run on windows XP (sp3)...i have installed synaptics pointer device driver v 8.3.4 . but the scrolling bar on right side of the touchpad is not working.
please help me with this.
thanking you
amit
Posted by ams_108 on
Anonymous
  • 518 Answers
Did you try mouse properties? if not go to Start, control panel, double click mouse.
Posted on Jun 24, 2009
Tip
How to enable 2 Finger Scrolling, like MAC ie, multi touch in Windows
Multi-touch or multitouch functionality has been attracting consumer attraction, thanks to iPhone and iPod Touch, two-finger-scroll in Apple MacBook with TrackPad, and Windows 7, which has built-in multi-touch mapping application, photo viewing program, and gesture support in Internet Explorer 8. Multi-touch is essentially a set of interaction techniques which allow computerusers to interact and control graphical applications with fingers.
However, for marketing reason, Synaptics official standard drivers for most Synaptics TouchPads does not support multi-touch Synaptics Gestures. Synaptics' drivers lock gesture features on all non-supported OEM notebooks and laptop PCs, except for certain gadgets such as ASUS EEE PC. So multi-touch is disabled even though touchpad hardware does support them.
But now if you want to experiance this awesome multi touch features, well there is good news. One guy has developed a modded driver for synaptic which will enable the multi touch functionality in a normal PC with windows.
The Synaptics TouchPad driver should support all Windows operating system such as Windows XP, Windows Vista and Windows 7. However, do note that the digital signatures of the modded drivers have been broken, and the drivers are no longer signed. Thus, there may be issue when use in 64bit operating system which enforces strict driver signing requirements.
Installation:
  1. Uninstall all current Synaptics drivers from Control Panel's Add and Remove Programs or Programs and Features.
  2. Restart the computer.
  3. Install the modded driver by running the setup.exe inside the ZIP archive.
  4. Windows should prompt a warning about unsigned driver. Continue to install the driver anyway.
  5. Restart the computer after installation is completed and Synaptics TouchPad driver is updated.
  6. In Device Manager's Mouse and Other Pointing Devices" section, Synaptics PS/2 Port Touchpad should have driver version of 10.2.4.
Now just play around a little bit and you will know how awesome this features are. icon_smile.gif
Also there is a two finger scrolling application which is a project hosted in google code. So this application is all you need if you just need the 2 finger scrolling functionality in windows.
This application can be found here:
Download: http://code.google.com/p/two-finger-scroll/downloads/list
The moded drivers from synaptic can be found here:
Download synaptics_v10.2.4.0_allOS_modded_b2.zip or touchpad_synaptics_v10.2.4_vistax32x64_xpx32x64_modded_build2.zip
Or you can just download all the required files from here:
Mirrors:
  1. Synaptics Multi touch mode (all) - Selfhosted
  2. Synaptics Multi touch mode (all) - Rapidshare - Recommended
IMPORTANT: Do not upgrade the Synaptics TouchPad driver if you love these touch features, as Sypnatics locks and disable the advanced touch features from driver v11.0.0.0 onwards.
on Oct 06, 2010 | Microsoft Windows Vista Ultimate Edition
Hi, I have a Compaq Presario F767NR. I downgrade it to xp. All my drivers are ok. But caps lock,scroll,touch pad blue light not working though its function is ok. I think led is ok. I find that for the...
Contact Microsoft Windows Support Toll-free phone number +1-877-242-3672 USA and find instant help to Downgrade windows in windows XP by Microsoft experts technicians. For More Details Visit Downgrade windows website:
1 8772423672 Downgrade windows 10 How to Go Back to Windows 7 8 8 1
Mar 01, 2018 | Compaq Presario F767NR Notebook
Problem with the HP G60-235DX PC Notebook Notebook Touchpad won't scroll. (Synaptics) Previously it would scroll with no problem, then suddenly quit. How do I restore the function? Previous...
Have you checked the settings of your synaptics? Usually there's an Icon on the taskbar for synaptics you can right click it and check if "disable touchpad if usb pointing device is present" is checked, if so uncheck it then your touch pad should work again.
Here's a link for a step by step instruction though this is for windows xp but steps are the same. Hope this works for you:
http://blueboxagency.com/helpdesk/?page_id=16
Apr 10, 2011 | HP G60-235DX Notebook
Mouse won't move on hp mini computer HP 2133
If anyone has recently purchased an HP Mini Netbook they might notice one thing not working after a fresh install of Windows 7. The touchpad scrolling doesn't seem to work after fresh install of Windows 7 x32. Read below to find out what you need to get it working. The nice thing is, Windows Updates should pick up everything else automatically.
  • First thing you will need to do is download the Synaptics Touchpad Driver from their website. I have included the link to the download page below
    http://www.synaptics.com/support/drivers
  • If this is a netbook, most likely you are running 32-bit of Windows 7 and so you will need to click on "Windows Vista 32-bit Edition v10.1.8" while on Synaptics' website.
  • Once you download it, simply double click on it to run it and then you will have to restart your computer.
  • No configuration is necessary. Once you have restarted, you will once again have your touchpad scrolling back.
  • Feb 17, 2011 | HEWLETT-PACKARD Computers & Internet
    The scroll bar on the touchpad on my HP Pavillion laptop model 9627 is not working. Can't find Syaptics program and it doesn't show up in control panel as a device manager nor can I find it in installed...
    First, download the latest Synaptics driver installer on the link below and save it to your Downloads folder.
    http://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
    Next, open Windows Control Panel, open Programs, and Features right-click the entry 'Synaptics Pointing Device Driver' and select Uninstall.
    When this has completed, restart the notebook.
    When windows have fully reloaded, open your Downloads folder, right-click the Synaptics installer and select 'Run as Administrator' to start the installation. When this has completed, restart the notebook again.
    When windows have reloaded, you may need to configure scrolling options etc - see the guide on the following link.
    Configuring The ClickPad.
    Regards
    I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
    Feb 04, 2018 | Synaptics PS/2 Port TouchPad
    I have downgraded the OS of my Toshiba Satellite A205-S7468 from Windows Vista to Windows XP SP3. System is having trouble identifying the proper Audio Driver. On Windows Vista, the Audio Driver is...
    You can try with an automatic driver tool, yes of course, it could be installed manually, but to avoid the hassles, you better opt for a driver utility.
    Download and install this software (Device Doctor Free). Once it's installed, run the program and click "Begin Scan", wait for few seconds until the scan completes and search the scan result for realtek, if so click it, the direct download page will open up, download and install the driver, that should work without any more hassles.
    If you have problem, let me know.
    Good luck.
    Thanks for using FixYa.
    Oct 27, 2010 | Toshiba Satellite L45-S4687 Notebook
    Driver problem
    in Xp SP3 that problum is so common that u have to install all or some drivers, now if u like the visual or other some thing of SP3, and u dont wanna install XP SP2 then u have to go to search over the Google to find the drivers for SP3, but i dont conferm that u will find them...
    install SP2,,, its better O.S.... I think..
    Good Luck
    shafky
    Jun 17, 2009 | HP Compaq Presario V6000T PC Notebook
    Inoperative touchpad scroll zone
    rwertheim,
    I have a MX8711.
    I assume you are running Vista.
    After you have updated your virus protector program and run a complete scan. You "could" be fixing it and if it is a virus problem, it is immediately reinfecting the driver. If it still doesn't work, I recommend you:
    1. Rollback the driver of your touchpad. If it was working, this might do the trick. You can do this at Control Panel > Mouse > Hardware (tab) > Properties (button) > Driver (tab). If it has been updated and that caused the problem, you probably can "Roll Back" to the previous driver and that option will be highlighted.
    2. If not, then your driver is probably corrupted. Go to Gateway Support and download the touchpad application file for your computer and SAVE IT TO YOU DESKTOP AND DO NOT RUN IT. Replacing only the driver usually doesn't work in these cases but try that first. Go to Control Panel > System > Device Manager > click on the (+) sign by mice and dbl click on the Symantics PS/2 Port Touchpad (or what ever yours is) > Driver (tab) > Uninstall. When you restart, it should reload the driver from the application that is still installed.
    3. If that dosn't work, I recommend uninstall the application from Control Panel > Programs & Features. Restart your computer and install the application you saved on your desktop.
    I hope this helps.
    Have a blessed day.
    Tracker Tom
    Apr 09, 2008 | Gateway MX8711 Notebook
    Unable to connect to the synaptics pointing device driver
    Try to reinstall your driver. Download it from here: driverupdate us . This tool usually keep my drivers up to date (perfectly for now) take a look
    Jun 09, 2007 | Logitech Marble Mouse Trackball
    HP Pavilion dv4000 Notebook Logo
    291 people viewed this question
    Top HP Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    Muntejaya Ginting
    Muntejaya Ginting
    efs_perpends
    efs_perpends
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
