I assume you want an external enclosure for this drive. Hard drives are built to standard dimensions and have the same power and data connectors, so any enclosure designed for a 3.5-inch IDE drive would work. Here's one I've bought several of for myself and others, and it's been reliable. There are many more available from many vendors. Just be sure you get one designed for IDE drives or that will take both IDE and SATA. If you get one meant for SATA only, the connectors inside won't fit your drive. Which enclosure you finally choose will depend on which you think is best (based on price, appearance, reviews, or whatever you look for), but any one will work.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket
