Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Jumper setting for seagate 7200.7oem hard drive
Posted by orwonka on
Anonymous
    President:
  • 2,653 Answers
Here you go
Hope this helps :)
Posted on Nov 24, 2009
Anonymous
    New Friend:
Dvd ram is not detected?
Posted on Mar 12, 2011
2 Related Answers
Computer Links
  • 2386 Answers
SOURCE: which is the correct jumper settings on Seagate
Hello Please see the image below for correct jumper setting cmptrlink_16.jpg
Hope this helps, if so do rate the solution
Posted on Jan 15, 2011
Anonymous
  • 93 Answers
SOURCE: Need to set the jumpers
Jumper settings can be found here:
http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f995a802efbd010VgnVCM100000dd04090aRCRD&locale=en-US&reqPage=Legacy
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Posted on Oct 21, 2010
2answers
I could not set the jumper ID as 3 in Seagate 73 GB model of Hard drive.It has 12 pins at the back of Hard drive.
You need a jumper on ID pin sets 1 and 2 (as if you were setting it for both ID 1 and ID 2)
These pin sets work like binary, so set 1 for ID1, set 2 for ID 2, and sets 1 & 2 for ID 3. In this mannar, with just the 4 sets of pins, you can have IDs from 0 to 15 (no jumpers to all 4 jumpered..1+2+4+8=15)
1234 set number
1248 binary ID (additive)
If you need further explanation, please post a reply here.
1helpful
Which is the correct jumper settings on Seagate Barracuda ATA IV 80 GB Hard Drive
How do you set the jumpers the Maxtor Quantum Fireball Plus AS 20.5 GB hard drive
Jumper settings for Seagate and Maxtor IDE (ATA) harddrives,
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=196299&NewLang=en
Follow the chart examples under the second heading down >
Maxtor (and Quantum) drives follow the jumper configuration noted below.
If I may also add;
1) http://www.youtube.com/watch?v=Ds1-JmbhGRM
2) http://www.youtube.com/watch?v=WwbboeMO7b8&feature=channel
2helpful
Need jumper setting for slave drive ide
If the drive is the Seagate Baracuda series, then simply remove all the jumpers from 8-pin jumper block and it will be a Slave drive.
If you want any other settings, the jumper settings are described here:
How to make sata hard disk a slave???
Look at the jumper settings. These jumpers are located near the data cable and the power port of the hard disk. Usually by default, this jumper is set to "Master". To make it a slave, just remove the black or blue jumper or please refer to the jumper guide table printed in you hard disk's label.
14helpful
2answers
5T020h2 jumper setup
No jumper is used on the J50 pins, when using the Maxtor 5T020H2 IDE harddrive, as a Slave harddrive.
In otherwords do not use a jumper on any of the jumper pins.
This is a PDF file of the Harddrive Specifications of the 5T020H2, 5T010H1, 5T030H3, 5T040H4, and 5T060H6 Maxtor IDE harddrives,
from Seagate. (Seagate bought out Maxtor)
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/dm_plus_60_ultra_ata_manual.pdf
The Jumper Settings are in Chapter 2, Page 5 (2-5)
Looking at the page number for the PDF file it's on Page 15.
2answers
WD drive won't work as master when Seagate 80GB drive connected as slave.
The jumpers on the Seagate must be set to slave.
otherwise they are conflicting for the Active partion and bootloader.
Regards
Richard.
5helpful
2answers
Hard drive settings
d5e7986.gif Jumper settings for Seagate ATA/IDE Internal drives <20gb & greater
For older/smaller drives visit www.seagate.com
Open Questions:
See all Seagate Barracuda 7200.7 ST380011A 80 GB Hard Questions
Top Seagate Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
