20 Most Recent Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive Questions & Answers
Seagate hard drive moved from one computer to another won`t boot
Now this is just my opinion but i tried to do the same thing one time and it would not work so I was left with one choice. Do a fresh install, I bought a second hdd and did a fresh install then plugged my original hdd in as a secondary so I could still access my old files. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
2/13/2018 1:47:01 AM • Seagate... • Answered on Feb 13, 2018
0answers
Ihave a sagate 320 inturnal HD that was installed on my desktop Comp. 1.5 years ago I am getting window massage to download all my data due to the HD failing. I am looking at the date code and it app
It sounds as if the SMART measurements on your Seagate 320GB hard drive are triggering the Windows message advising that the drive is failing. You would be best advised to backup your data from this drive to a different drive or on to DVD media (depending on how much data is involved). To test the failing Seagate disk, download a copy of Hiren's Boot CD which is a CD image file (.ISO) and must be burnt to a blank CD disc - then boot the computer with the failing disk from this CD - then select DOS Programs on the initial menu, then choose Hard Disk Tools and then HDAT2 - this is a tool which will let you try to recover any bad sectors on your boot disk. On the Hard Disk Tools menu there is also a SMARTUDM - HDD S.M.A.R.T. viewer which will let you examine exactly which areas of the Seagate disk are giving the problem leading to the failure message.
1/8/2012 7:43:28 PM • Seagate... • Answered on Jan 08, 2012
I've been noticing a squeaking sound
Good day,i think the problem would be you hard disk sir,better to change a new one.tnx
8/17/2011 8:03:18 AM • Seagate... • Answered on Aug 17, 2011
Seagate 7200.10 160 gb in
Now I'm not sure I'm going to be able to sort this out for you but I can think of a couple of things to try.
a) you mention 2 other O/S PC's.............if they've got XP on them, they're not going to work, XP can only see drives up to about 120 Gb.
b) Make sure the jumper setting on the back of the drive is set to "Slave" and try on a machine with Vista or later, Linux or a Mac.
c) If you don't have acces to the latter 2, try using Ubuntu, its a linux based operating system. Google Ubuntu, download the .iso file and burn it onto a CD. All the instructions are there.
d) insert the CD and reboot, with luck your bios is set to boot from a CD first. Ubuntu will start up and ask you if you want to try it or install it. Select "Try it". This should load Ubuntu without changing anything on your PC.
e) Once up and running, plug your disk in using the enclosure or if in your PC click on "Places" at the top of the screen, with luck, your hard drive is in the list.
After this, I'm stuck ................ good luck
7/15/2011 7:02:21 PM • Seagate... • Answered on Jul 15, 2011
Can not read
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
2/5/2011 3:41:24 PM • Seagate... • Answered on Feb 05, 2011
My pc can not find this drive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
1/31/2011 1:51:14 AM • Seagate... • Answered on Jan 31, 2011
When i log in BIOS
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
1/4/2011 1:04:38 PM • Seagate... • Answered on Jan 04, 2011
I want to detect driver Thanks
There is _NO_ need for any additional device-driver -- Windows "natively" supports all disk-drives.
12/18/2010 3:42:57 PM • Seagate... • Answered on Dec 18, 2010
How many times a harddisk can be formatted?
The ram, processor and the motherboard will not be affected, but the hard disk will be eventually. The hard drive will be affected but in a slight way. Try to make a recover image for your O.S.
3/14/2010 3:20:57 PM • Seagate... • Answered on Mar 14, 2010
How to read date codes
date codes are usually only 4 characters long so this one is the 48th week of 2007 the last 4 maybe the day of the week.
12/15/2009 2:47:16 PM • Seagate... • Answered on Dec 15, 2009
The hard drive is not a year old but has now
Hello, I think it could be the writer head. backup your data and send it on warranty.
6/25/2009 12:04:57 PM • Seagate... • Answered on Jun 25, 2009
Seagate satat error
the firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
5/5/2009 9:26:45 AM • Seagate... • Answered on May 05, 2009
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
3/2/2009 6:01:36 PM • Seagate... • Answered on Mar 02, 2009
2answers
Please share image and location of TVS diode in ST3120827AS seagate hard disk circuit board
For the Seagate hard disk model ST3120827AS, the TVS diode is typically located on the circuit board (PCB). TVS diodes are designed to protect electronic circuits from voltage spikes and transient events. They are usually small, with two leads, and look like small cylindrical or rectangular components.To locate the TVS diode on the circuit board, you may need to refer to the hard drive's datasheet or schematic diagram, if available. Additionally, you can try searching for online resources or forums where individuals share information about hard drive components and their locations.Regarding the Cisco Nexus Network Switch , it's important to note that specific details about the internal components, including the location of TVS diodes, may be proprietary and not readily available in publicly accessible documents. For detailed information about the switch's internal components, you may need to refer to Cisco's official documentation or contact Cisco's supporthttps://www.serverblink.com/n3k-c31108pc-v-cisco-nexus-network-switch/
2/19/2024 8:12:49 PM • Seagate... • Answered on Feb 19, 2024
The hard disk not detected
Try downloading TESTDISK and see if the drive is detected on the List within TESTDISK. If it is then you may be able to restore the boot sector within TESTDISK.
5/22/2019 10:07:55 AM • Seagate... • Answered on May 22, 2019
Seagate barracuda 7200.9 connect to USB
You will need an external Hard drive adapter case. This will probably come with driver disk. If already and external drive it may have internal firmware which talks directly to the PC. Just install drivers, if any, and plug unit in. Follow screen prompts.
11/23/2017 3:49:02 PM • Seagate... • Answered on Nov 23, 2017
Can a power interrupt during hard drive installation cause a "Boot manager missing" message?
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation. As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable. If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive. For that type of recovery I use gparted, which can be downloaded for free from http://gparted.org/livecd.php Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
3/10/2017 6:40:44 PM • Seagate... • Answered on Mar 10, 2017
2answers
IDE to sata adaptor +barracuda 500GB HDD
5/17/2016 11:53:59 AM • Seagate... • Answered on May 17, 2016
Seagate Barracuda 7200.10 ST3160815A - 160GB - 7200rpm - 100MBps Ultra ATA/100 (ATA-6) - ... 160 GB EIDE Hard Drive Logo
18 questions posted
Top Seagate Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
BARRACUDA Seagate
  • BARRACUDA Seagate
Most Popular Question
seagate sata hdd error
  • Computers & Internet
