The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.The Fault seems to be failure of the control unit as the flash worked maybe with a coincidence.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the Canon service as you do not have to run around for spares.
A total failure of the control board might need the support from the dealer for the required spare and so instead of tampering it will be worth a try.
I searched for 'no power' under the faq's for the Canon Powershot sx110 Digital Camera on the canonusa.com site and got the following result:
Issue: Lens will not extend when camera is powered on. (No error Message)
Solution: The PowerShot SX110 IS requires service.
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below:
Request a Repair Online
You can conveniently pre-arrange repair service with a Canon Factory Service Center through Canon's website.
Find a Service Location
Search to locate a repair service center and obtain further instructions.
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
If
you hear a noise from the lens when you try to take picture or During turn
on/off time then it's a lens guide pin problem OR Somehow its jammed or
damaged. It's happens when the camera pressed or drop down during turn on mode
or long time not use.
For the solution you need to
follow the steps.
1.
Turn off the camera and remove the memory card and clean the external body of
the camera and make sure in place of the lens there is no dust or damaged sign.
2.
Now turn on the camera without memory card & make sure the battery are
fully charged.
3.
If the lens not moving then give a little shake or thrust by hand ( carefully
very slow) and then wait for a moment. If no changes then turn on the camera
and give a little twist an anti clock side and leave for few second. It is
risky ( Do it slowly at your own risk)
4.
If nothing change then reset the camera setting from the menu option.
After
following all steps, if the camera does not start working then you need to
visit service center for replacing the Lens or Repairing. If you have any more
questions ask me I fell happy to answer your question. Thank you.
Googling the same thing I already have does not count as an expert solution.
