20 Most Recent Sony Cyber-Shot DSC-W570 Digital Camera Questions & Answers
The gears inside are not stuck, in fact gears inside seems broken and camera needs new lens assembly replacement.
Sony Cyber-Shot... | Answered on Aug 30, 2016
hi,
check the battery's shape, if it is bulged replace it, check the panel keys if any of it sticky or loose, use contact cleaner spry on the keys.
Sony Cyber-Shot... | Answered on Feb 09, 2016
Sure your battery has enough power to charge the flash? charge the battery and try again.
Sony Cyber-Shot... | Answered on Mar 17, 2015
Press the MENU button. Select the toolbox icon. Select the wrench-and-hammer icon. Select the second item on the menu.
Sony Cyber-Shot... | Answered on Feb 17, 2015
Dry your phone with simple towel. Then put your phone in a bag of rice for over 24 hours. Take out your phone and try to start it and see if it works. I am talking about phones in which battery can't be separated. If you could separate the battery then, dry it from outside then pull out the battery and dry gently inside then put it in a bag of rice overnight and start it next day.
Sony Cyber-Shot... | Answered on Jul 09, 2014
If the battery can come out, pull it immediately to prevent further electrical and corrosion issues. If it landed in dirty water, you should rinse it off as it is already wet it won't hurt anything further.
After that there are a few options but the main goal it to be sure you get it all the way dry before turning it on again.
The last time my phone went in the water I put it in an OPEN ziplock bag full of rice then placed it by the heater.
If you are like me and it is hot enough in your house, you could turn your oven to it's lowest setting, 150 degrees or less, and leave your item in there for an hour or more. I would not turn it back on for at least a day or two. if you see and steam on the inside of the screen, it is not dry enough to turn on.
Sony Cyber-Shot... | Answered on Jul 01, 2014
Short answer, No.
The potassium in a banana is not in the same concentration nor is it purified.
It is similar to how karoseen come from crude oil. a match in the oil will simply go out. The karoseen on the other hand will burst into flames.
Sony Cyber-Shot... | Answered on Jun 23, 2014
I suggest you open up the unit as much as possible, then pack it in rice about 2 inches deep all around it in a box and let it sit for at least a week. The rice is good for drawing out moisture from anything. Russ
Sony Cyber-Shot... | Answered on Jun 05, 2014
Try cleaning the card contacts...
Sony Cyber-Shot... | Answered on Apr 23, 2014
the flash light works only on low light environment, check your setup manu, change the setting to always flash if you need.
Sony Cyber-Shot... | Answered on Jan 29, 2014
Has it been dropped? I had a cabera that was dropped and the lense would not go all the way back in which caused the lense covers to not close.
Sony Cyber-Shot... | Answered on Oct 22, 2013
If it is a SD or SDHC memory card, there is a small write protect switch on the side of the card. Remove the memory card from the camera and slide the switch to the unlocked position.
Sony Cyber-Shot... | Answered on Oct 11, 2013
Reset the unit to default
Sony Cyber-Shot... | Answered on Jul 17, 2013
I have had success with this camera photo recovery software... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Sony Cyber-Shot... | Answered on Feb 08, 2013
The date and time (and a lot more) are automatically stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sony Cyber-Shot... | Answered on Jan 10, 2013
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Sony Cyber-Shot DSC-W570 Digital Camera Logo
90 questions posted
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
memory card locked
  • Cameras
