HP DesignJet 500ps (42 in.) InkJet Printer Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please i have this problem: theri'nt paper in the printer but my printer is blocked with the message "system error 80:01 sever error 0x9010001 in line 1587
Level 3:
  • HP Master 7,733 Answers
  • Posted on Nov 24, 2010
HP Master
Level 3:
Answers
7733
Questions
0
Helped
1865077
Points
21487
2answers
My printer canon mx328 error 6000
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this mistake.
Canon Printer Error Code 6000 refers to something in the printer that interferes with the movement of the carriage. In any case, I've been able to locate the problem: a piece of torn paper on the left side of the printer. Hard to get there However it's likely. The printer is running again! But often this is induced by a software error. Foreign objects, such as dust spores, pieces of paper, sticks, stickers, or other objects, block the proper opening of the paper feed tray. Due to the jam, the printer has an error of 6000.
Reasons for Canon printer error code 6000: The printer feed tray is wrongly fitted. A huge volume of documents next to the printer. The line feed is scratched or coated. Offer several print commands on paper at once. Faults in the sensor unit or in-line feed slit.
Our service: 24/7 support with the Printer expert team.
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
I can not print from my lexmark t642 printer. I get this message " Remove paper from Standard paper bin." I do not have any paper in that area.
If there is no paper on paper bin and you are getting error to remove paper from the standard paper bin, please check for paper jam. it possible that paper stuck right on the path on the paper bin.
For further assistance, please contact Lexmark Technical Support.
2helpful
Printer notes "Error 6000". It is being used
Take a close look at the printer and the paper tray. The error usually means that the paper output tray is closed (or something is blocking it from opening). Remove the object blocking the paper tray and pull it fully open (including the extension). Then turn off the printer and turn it back on. The error can also occur when a book is being scanned that blocks the paper tray.
Some documentation on the Canon error messages for the MX860 is here: https://www.canon.ie/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX860.aspx?faqtcmuri=tcm:24-644260&page=1&type=faq .
I hope this helps.
2answers
3answers
1helpful
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
1helpful
The printer will not feed the paper into the machine
Hmm, this is too general symptom too troubleshoot. But never mind. Printer cannot feed the paper for several reasons:
Auto sheet feeder (paper feeding mechanisme) is faulty;usually generate error message on the monitor or/and error code on LCD display
Paper end did not reach paper sensor because the paper not set properly or another material block the paper path.
To find out more about this error,please check the following article exclusively for Canon printer.
Paper feed error
Paper jam error
Source: Canon Inkjet Forum
Printer displays message "Printer error..." and error light is on
Turn off your printer. Then disconnect it from your computer. Open up the whole scanner unit to check if there are obstructions blocking the way of the printhead or if there are obstructions down the paper feed area. Press the part of the cartridge cover that is showing to make sure that it is closed properly. Reload the papers. Turn the printer back on. Unfortunately, there is no software reset for the error. Please log on to epson.com to find a local servicer near to your area if your unit is over a year old already. Click on drivers and support then click on help me find a service center.
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
k24674
Grand Canyon Tech
Grand Canyon Tech
