I've been trying to install 2x512 stick into my notebook ,
tired 2x 512mb 2700 came up as I had 93mb of ram
tried 2x 512mb 2100 came up as I had 193mb or ram
odd thing is that I had 2x256mb of 2700 and it works fine
any clue on what it might be
Fixing a relic 15 year old square laptop, to want ends?
its junk now, the CCFL inside are useless now, too old
never spend cash on any monitor or PC with CCFL back lamps.
"came ,up"
who came up.?
bios or windows. told you this?
sure wrong RAM.
finding ram to fit and work in any relic PC now is not easy
they dont make them now so are new old stock.
why not buy a PC 2010 or newer, used.
work that a end.
with hope and a real future.. yours is no good. sorry. but that is a fact, never throw good money after bad.
SOURCE: Acer travelmate 230
yes they should do, the board should be backward compatable, as 2100 266mhz is hard to come by nowadays
SOURCE: can I install 1gb of ram on a compaq evo n610c
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
SOURCE: The memory I install to Armada wont boot
You can try updating the bios to use the new memory or you may have to buy a different brand of memory to work in the computer.All memory is not made the same.Some work in one machine and not in another.You won't know till you try it.
SOURCE: Compaq NX6325 Laptop Manual says
I have researched this and u have but one usable RAM memory slot, the other slot is not supported on your board, suggest u use a 1-2GB in the main slot where the stick goes that u have, go the web link for memeory sticks that can fill your needs up to 2GB in the one slot.
http://www.edgetechcorp.com/memory/upgrade.asp?cid=31012
