20 Most Recent ASUS P5VDC-X Motherboard Questions & Answers
SOUND IS AVILEBALE BUT NOT FULL SOUND
ASUS P5VDC-X... | Answered on Apr 21, 2015
You may encounter this error when installing the Realtek High Definition driver in XP. You can download the driver here.
Here is the solution:
  • Open Device Manager (Start> Control Panel> System> Hardware)
  • In the "View" menu , select "Devices by connection":
  • Disable and uninstall by right clicking on " UAA High Definition Audio Bus Driver for Microsoft":
  • You can now install the drivers normally and without error.
Hope this helps,
ASUS P5VDC-X... | Answered on Nov 11, 2013
Press F8 during boot and go into Safe Mode. The roll back with System Restore. It is located in Start > Programs > Accessories. Or a link in help under tools.
You may have to try a few dates. This should help, if not repost with erros or more details. gl
ASUS P5VDC-X... | Answered on Dec 28, 2012
Just bring it to a pc repair shop near you.
ASUS P5VDC-X... | Answered on Jun 30, 2012
Hi, you can download a manual here at the ASUS site:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VDCX/#download
Here you also find drivers.
Hope this as helpfull.
ASUS P5VDC-X... | Answered on Aug 12, 2011
did you plug in the 24 pin main of the power supply in some also take a 4 pin as well on board jim
ASUS P5VDC-X... | Answered on Jul 17, 2011
This motherboard has an 775 socket - so long at the processor supports the 775 socket then it will be compatible.
775 does support dual core click here for a good list of the processors and the motherboards they will support as it depends on the exact chip you are trying to install.
ASUS P5VDC-X... | Answered on Jan 23, 2011
ASUS P5VDC-X supports Intel Celeron, Intel Pentium 4, Intel Pentium D Processors. The motherboard is capable of supporting the Intel LGA775 Pentium 4, the dual-core CPU, as well as compatibility of either 64- or 32-bit architecture.
Please refer to Product Manual for ASUS P5VDC-X Motherboard for further details (if required)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
ASUS P5VDC-X... | Answered on Jan 03, 2011
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
ASUS P5VDC-X... | Answered on Dec 14, 2010
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
ASUS P5VDC-X... | Answered on Nov 19, 2010
you can download you drivers from this links i have given below
http://www.nodevice.com/driver/P5VDC-X/get34059.html
http://www.driverstock.com/ASUS-P5VDC-X-driver-download/6-9-10183/index.html
hope that it will be help full thanxs
ASUS P5VDC-X... | Answered on Oct 14, 2010
Really, I don't understand what language that is, If it was in english you could probably get more help us
http://babelfish.yahoo.com/ to translate what your saying
ASUS P5VDC-X... | Answered on Sep 10, 2010
Did you try reinstalling the Sound card driver. Kindly check if the driver supports Windows 7 or you need to get the latest driver for Windows 7. Some tips given below can help you diagnose the issue related to your Motherboard.
If you have the motherboard CD, try this:
Go to device manager and uninstall the sound driver.
When installing it again, choose to search for the driver. Then go to the cd>drivers>audio>vista.
If you dont have the cd, just download the vista drivers from asus.com
ASUS P5VDC-X... | Answered on Jul 01, 2010
all asus drivers can be found by researching your sysbd's model number on the following page: http://support.asus.com/download/download.aspx?SLanguage=en-us
ASUS P5VDC-X... | Answered on Apr 22, 2010
ASUS P5VDC-X Motherboard Logo
52 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
asus p5vdc tvm support intel dual core
  • Computers & Internet
