Http://www.geeks.com/details.asp?invtid=K8A9-8SB3-BULK&cat=FAN The replacement by this part will be easier than trying to find a new fan for the ULTRA.
THEY ARE NOT UNIVERSAL! Is it the blade or blade holder? What make/model of fan do you have? You need to buy a whole set of whatever you need or most likely your fan will wobble.
All of the fan blades are one piece along with the hub which is attached directly to the motor pulley (if fan is like the fan which is pictured).
This is true even if there is some kind of attachment between each blade and the hub -- it comes as one piece.
If you can purchase it, or another which will function like it, there are two places you may go to:
1) Sears sells parts for everything they sale. If you didn't get your fan from Sears, then you can still go to Sears and possibly locate a fan which is close enough.
2) Appliance parts stores (like A&M Parts/Johnstone supply) sell fan blades.
Before you begin, remove the broken fan blade (including hub). Matching the diameter and pitch of the blade and the hub to motor attachment is the goal. It can only be of good to know the make and model, but it is not necessary.
:o).
you could get this on Ebay
if you dont have an account you will need to create one Add Email adress Add Bank Acc Add Credit Card also add your postal adress
also add a paypal account when you get to the paypal
login page at the bottom you will see new to paypal sign up tab paypal to create an account
paypal registration
password ,bank card /credit card,phone numbers home/mobile ,email adress
and a postal adress be very specific when you
type in the search always ask questions?
before you make a purchase and keep the email/s for security reasons if the
item arrives and its not as described you will even see the
pictures of your item so you cant make a mistake and get them home delivered hope this helps
check power supply, check supply circuit fuses, if all good trace wire to fan motor itself check for current, if voltage is present check ground circuit for open.. if all checks good fan motor is bad or fan blade splines are stripped cause motor shaft to spin without fan blade turning, have also seen where a pencil, paper clip debris has broken fan blades when people store stuff on top of dash board panel , debris falls into vent back into fan housing resulting in a broken fan blade... check all
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
