Question about Ultra (ULT31502) UPS System
How to correctly install batteries in ultra model 1000ap?
Posted by guido11u on
  • Anonymous Mar 26, 2014
    Does not charge
Grandpa Fixi
    New Friend:
Place your two new type CB1270 batteries on their sides, one on top of the other in front of you with the battery connectors closest to you and with the battery connectors to your left. Connect the short (2 inch) jumper cable between the two center battery posts (1 red/1 black). Slide the battery stack into the chassis with the battery posts to your left as you face the front of the UPS and be careful that the battery posts do not touch the metal chassis. When the batteries have been slid completely into the chassis, connect the heavy red wire from the circuit board to the red battery connector at the bottom of the battery stack and the heavy black wire from the circuit board to the top black battery connector. If you have doubts about your wiring, use a DC voltmeter set to the 50v range and touch the red probe to the red battery post at the bottom of the battery stack while touching the black probe to the black battery post at the top of the stack. The reading on your meter should be somewhere between +24 and +26v depending on the charge level of your batteries.
Posted on May 01, 2011
I just bought new batteries for my Pride Ultra Go Go, but can't get them to start charging when I plug the charger directly into the outlet. Help please.
1.Make sure you installed them correctly.
2.Check the voltage on the batteries. If either (or both) register less than 11 volts, either return them for ones that have 12 volts, or attempt to bring them up to 12 volts with an automobile battery charger. Once brought up to 12 volts, install them, then make sure you recharge them with the supplied charger/adapter before or when the on-board indicator it shows low (red). If the battery voltage drops too low, the supplied charger simply won't even try to charge them.
Aug 06, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Typ of battery
Mine has 2 12 volt 12 ah agm batteries model ub12120 if that helps>
Jul 12, 2010 | Pride Mobility Products Go Go Ultra X 3...
Jet 3 ultra needs new battery, where do you get them?
you can get them from batteries plus. make sure you look at your current batteries and request the correct volts amps and size.
Mar 15, 2010 | Jet 3 Ultra Power Chair
Lost my instalation cd so pls want edgemodem driver model:E67II
Post a request on this website, seemed to work for another user of an edge modem!
Jun 29, 2009 | D-Link DWL-1000AP and DWL-120 Wireless USB...
Battery
It need to replace 2 piece of regular 12V.7A SLA battery. It is easy to buy in the market.
Jul 24, 2008 | Powercom BNT-1000AP (dspcmbnt1000ap) UPS...
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Ultra (ULT31502) UPS System Logo
2,269 people viewed this question
Top Ultra Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Vebble
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
