Cars & Trucks Logo
Anonymous Posted on Nov 16, 2010
I have a fairly loud humming noise when i am driving my 2001 saturn sl1. This occurs when i am driving straight or turning to the left. If i turn to the right the humming noise goes away. (it sounds to me, the driver, that the noise is coming from the front left of the car).
  • Anonymous Nov 16, 2010
    I have replaced the driver side wheel bearing but I am going to try the passenger side...Thanks!
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Nov 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
29166
Points
244
I would start by checking your wheel bearings. Do this by pushing back and forth on the top of your tire or car near the tire. If the tire wobbles back and forth at all your hub assembly should be replaced. For this problem I would check for this first.
1helpful
5answers
My 2002 saturn sl1 is making a loud humming noise in the front while I drive. the faster I go the louder it gets. the tires show no sign of uneven ware, the brake pads are new. I bought the car used two...
Hi, the likely problem is a worn out wheel bearing. See if it quiets down when turning. If it quiets when turning right, it's the right bearing, and vice-versa. Please let me know if you have more questions, and thanks for using FixYa.
My car makes a loud humming noise while driving when turning left. its fine while going straight or right. Wheel bearing?
Possible. If you have changed tires lately, make sure they put the right size tires on. If they went up in size by any measure, it could be rubbing on the tire well and thus making the noise. Check the users manual if you have it and check to make sure the tire sizes are correct. Also check your power steering fluid. That would make a humming or moaning noise but it would be noticeable while turning.
Very LOUD banging noise from front left wheel
the right outer tierodending needs replaced.
My alero makes an awful sound when I turn to the right while driving at any speed. Going straight it makes some noise and when I turn left it goes away. I it is a loud groaning, humming sound like...
jack car just enough to take the weight off the road wheel, then using a tyre iron, see if theres any movement in any bushes,only try this on the flat with bricks under the chassis frame just in case....
1helpful
Vibration/Humming/Grinding noises when stopping or turning left.
when turning left vehicle distributes weight to right front wheel bearing causing load. since u describe a noise in right front while driving straight i would suspect failed right front wheel bearing. see if your noise changes/goes away while turning right that should tell u 4 sure
1helpful
2answers
Faint to loud humming noise while driving and turning...
Could be either a loose belt or you are low on power steering fluid,or the power steering pump could just be worn out.
2helpful
I have a 2003 Pontiac Grand Am and it makes a loud noise
Bad front wheel bearing on the drivers side. When you turn left it shifts more of the vehicles weight to the passenger side and takes the pressure off of the drivers side. Not uncommon but will need attention soon. Hope this helps
Very loud noise when I drive straight or left
did you check front fender liners ? sl is bad about coming lose in front .
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
