Mercury Master
- Posted on Nov 14, 2010
Re: How do you get the capierer pin off to put front...
Section 06-03: Brakes, Front Disc
1999 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION
Brake Shoe and Lining
Removal
Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478) . Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
Raise vehicle on hoist.
Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120) , front disc brake rotor shield (2K004) or front wheel knuckle (3K185) .
Remove rear brake pin retainers (2N386).
NOTE: It is not necessary to disconnect hydraulic connections.
Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125) . Do not pry directly against metal caliper piston or damage will occur.
NOTE: To prevent damage, do not allow disc brake caliper to hang by the front brake hose (2078) .
Position disc brake caliper out of the way.
Remove inner outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate .
Inspect both rotor braking surfaces. Minor scoring or buildup of lining material does not require machining or replacement of front disc brake rotor.
remove the 2 pins, #10 in pic. Usually has a dust cover over pin accessopening. Usually torx haed or hex head bolts (pins).
