Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
SOURCE: Ultimate Care II washer will not agitate or spin
Your lid switch could be the problem. It has 3 wires: black red which are hot and green which is ground. Unplug that lid switch and check for continuity between black and red with the lid shut. This video shows where the lid switch is located
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Washer works great, but only
This is a common problem with Whirlpool washer.
Examine the transmission spline for wear.
When stripped, this prevents the agitator from properly gripping the
transmission shaft. The spline or the agitator itself may need to be
replaced.
In other words, the Spline or agitator of the top half of your washer is the cause of the problem. These two parts may need to be replaced.
Good luck.
SOURCE: whirlpool ultimate care heavy duty super capacity
Hello, kmontano
I
am trying to help you out here. Maybe this will help some? I am know on
Fixya as the cleanup expert pro. Which means I spend my own personal
time to seek out customers that maybe have not had there problem yet
solved by the other fantastic great experts. I do this on my own for
free. Think of me as a Specialized Trouble Shooter.
I have found
out that it appears that lots of customers appreciate my efforts and
help. So, I thought I would take some of my own personal time to
see if I can help you. Even though this Informational site may not have
your exact model or brand, But this site will help you a lot. Here is
the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please
if this helped you at all, if you can find the time and in your heart
to rate my help and some kind words written would be appreciated for my
free help, I would appreciate it. Like I said I
just try to help, If anything this is good information for future
problems. If you felt that my free help was a waist of time for you, I'm
sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here
is also my direct link to my own pages of other areas of my expertise
for other problems you might have in Automotive, Appliance, and
Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
