I have samsung R538 Laptop.
I installed windows today. I am unable to activate my wifi.
Please suggest me how to activate it.
Mail me at [email protected]
Does not switch on? Do you mean you are unable to make Wifi enabled? If so, then it is suggested you contact HP support to provide the advice.
Before you speak to HP, you could try to update the wireless driver. A lot of wifi problem are caused by the outdated or corrupted driver. You could use a third party tool to scan your computer. OSToto Driver Talent is a good program. With this tool, the scanning result will be listed within a few seconds. Then you could if there is a driver issue. Driver Talent Download Update and Fix Drivers Ostoto
XP is dead for microsoft !
May be you have not paid the right to use old XP on this computer ?????
( genuine program ).
All is function of what happen, and errors messages ??
the wattage of the ac adapter you're using is different from the required wattage of your computer. this happens when you use a different charger or the charger had not been cared for well.
You need to check first if the wireless switch is turn on.If it is on, check the function key for the wireless. Some computers have function key. Sometimes it is combination of fn and f5. Press those keys at the same time and you should see a pop up window and check if the current status is on. If it is on, uninstall/reinstall the wireless driver in device manager. go to programs and features and look for lenovo readycom, uninstall the software and restart your computer. If this didn't work. You need to do re installation of your operating system.
HI , Listen dear compaq c700 models does not support windows xp , so i suggest you to please install windows vista home basic minimum.... all the drivers needed by this os is available on www.hp.com..... hope you must be satisfied otherwise no solution is dere.... b.bye
If you are connecting to a WiFi Access Point from one laptop, and you know the encryption settings and the SSID (name of the WiFi connection) then you can plug that infomation into your other laptop WiFi connection page and you should be able to connect.
The configuration is very similar to XP.. you just need the information to put in on the Vista..
