Hello - A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Another possibility is an air leak and the cool air is causing the frost buildup. I suggest contacting a professional to move forward accurately and have them check the coolant system.
Do you mean not sealing and allowing air to enter ?
the seal broke - water is dripping out
