SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
SOURCE: My Panasonic KX-TG2352PW 2.4GHz cordless phone has loud static.
I don't yet have a solution, but I do not want to be obligated to pay for your advice...so I will find another way to solve the problem. Thank you.
